Updated on 2023-03-03 GMT+08:00
Importing Data From a Local Path or OBS
  1. On the GES management console, click Metadata Management in the navigation tree on the left.
  2. On the Metadata Management page, click Import in the upper left corner.
  3. In the Import dialog box, select Local or OBS for Type to import a metadata file form a local path or OBS.
    • Import a metadata file from a local path.
      Select Local File: Click Upload to select the metadata file.
      The file must be in the XML format.
      Name: Enter a name for the metadata.
      Storage Path: Select an OBS path for storing the metadata file.
    • Import a metadata file from OBS.
      Select File Path: Select the metadata file from OBS.
      • The file must be in the XML format.
      • Ensure that you have uploaded the metadata file to your OBS bucket.
  4. Click OK to import the metadata.
    If the import is successful, the metadata file is displayed on the Metadata Management page.
