Updated on 2023-03-03 GMT+08:00
Filtered n-Paths
Overview
The filtered n-Paths algorithm is used to find no more than n k-hop loop-free paths between the source and target vertices. The start vertex (source), end vertex (target), number of hops (k), number of paths (n), and filter criteria (filters) are the parameters for the algorithm.
Application Scenarios
Any network
Parameter Description
Table 1 filtered_n_paths parameters
Name
Mandatory
Object Type
Value Range
Default
source
Yes
Source vertex
String
Internal vertices
None
target
Yes
Target vertex
String
Internal vertices
None
k
Yes
Number of hops
Int
[2,6]
2
n
Yes
Number of paths
Int
[1,1000]
