Updated on 2023-03-03 GMT+08:00
Subgraph Matching
Overview
The subgraph matching algorithm is used to find all subgraphs of a given small graph that is isomorphic to a given large graph. This is a basic graph query operation and is intended to explore important substructures of a graph.
Application Scenarios
This algorithm is applicable to fields such as social network analysis, bioinformatics, transportation, crowd discovery, and anomaly detection.
Parameter Description
Table 1 Subgraph matching parameters
Name
Mandatory
Type
Value Range
edges
Yes
Edge set of the subgraph to be matched. The vertex ID must be a non-negative integer.
String
The value is in standard CSV format. The start and end vertices of an edge are separated by a comma (,), and edges are separated by a newline character (\n). For example, 1,2\n2,3.
vertices
Yes
Label of each vertex on the subgraph to be matched.
String
The value is in standard CSV format. Vertices and their labels are separated by commas (,), and labels are separated by newline characters (\n). For example, 1,BP\n2,FBP\n3,CP.
directed
No
Whether the graph is directed
Bool
The value can be true or false. The default value is true.
n
No
Maximum number of subgraphs to be searched for
Int
The value range is [1,100000]. The default value is 100.
batch_number
No
Number of queries processed in batches each time
Int
The value range is [1,1000000]. The default value is 10000.
statistics
No
Whether to display the number of all subgraphs that meet the conditions
Bool
The value can be true or false. The default value is false.
