All Shortest Paths of Vertex Sets
Overview
The Shortest Path of Vertex Sets algorithm finds the shortest path between vertex sets.
Application Scenarios
This algorithm can be used to analyze relationships between blocks in scenarios such as Internet social networking, financial risk control, road network traffic, and logistics delivery.
Parameter Description
Parameter |
Mandatory |
Description |
Type |
Value Range |
Default Value |
sources |
Yes |
Source vertex ID set |
String |
The value is in the standard CSV format. IDs are separated by commas (,), for example, Alice, Nana. The maximum ID number is 100,000. |
targets |
Yes |
Target vertex ID set |
String |
directed |
No |
Whether to consider the edge direction |
Boolean |
true or false. It is a Boolean value. |
false |
Precautions
If a vertex ID contains commas (,), add double quotation marks to it. For example, when Paris, je taime and Alice IDs are used as sources, the ID set is "Paris, je taime",Alice".
Example
Set parameters directed to true, sources to "Alice,Nana", and targets to "Lily,Amy". The JSON result is displayed in the query result area.
