Origin-Destination Betweenness Centrality
Overview
The Origin-Destination Betweenness Centrality algorithm calculates shortest paths that pass through a vertex/edge, with the origin and destination (OD) specified.
Application Scenarios
OD Betweenness Centrality can be used for tracing man-in-the-middle in social networks and risk control networks and identifying key vertices in transportation networks. It is suitable for simulating busy transportation sections during peak hours. It is also widely used for social networking, financial risk control, transportation networking, and city planning.
Parameter Description
Parameter |
Mandatory |
Description |
Type |
Value Range |
Default Value |
directed |
No |
Whether an edge is directed |
Boolean |
The value can be true or false. |
true |
weight |
No |
Weight of an edge |
String |
The value can be an empty string. If this parameter is left blank, the weight and distance of this edge are 1 by default. You can set this parameter to a property of the edge, and the property value will be the weight. If the edge does not have the specified property, the weight is 1 by default.
The weight of an edge must be greater than 0. |
OD_pairs |
No |
Pairs of OD vertices |
String |
The value must be in the standard CSV format. The start vertex (origin) and end vertex (destination) are separated by commas (,), and the start and end vertex pairs are separated by newline characters (\n), for example, Alice,Nana\nLily,Amy. |
seeds |
No |
ID of the hot spot vertex |
String |
Data that will be imported when the data of OD vertex pairs is unknown. The value is in the standard CSV format. IDs are separated by commas (,), for example, Alice, Nana. A maximum of 30 IDs are allowed. |
modes |
No |
Hot spot vertex type |
String |
attendees |
No |
Number of participants at each hot spot in seeds |
String |
The value is in the standard CSV format. Numbers are separated by commas (,), for example, 10,20. The value ranges from 1 to 1,000,000. |
When you perform approximate OD-Betweenness calculation, either OD_pairs or seeds must be specified. If both are specified, the OD_pairs vertices will be used for calculation by default and seeds will be ignored.
Precautions
None
Example
Ser weight=length, directed=true, OD = Alice,Nana\nLily,Amy and view the result.
