Updated on 2025-03-05 GMT+08:00
Viewing Monitoring Metrics
It takes a period of time for transmitting and displaying data. The GES status displayed in the Cloud Eye monitoring data is the status obtained 5 to 10 minutes before. You can view the monitoring data of a newly created graph 5 to 10 minutes later.
  • The created graph is running properly.
  • The graph has been properly running for at least 10 minutes. For a newly created graph, you need to wait for a while before viewing its metrics.
  • You can view monitoring data of graphs in the running, importing, exporting, and clearing states.
  2. In the navigation pane, choose Graph Management. In the Operation column, choose More > View Metrics. The Cloud Eye management console is displayed.
  3. On the monitoring page for GES, you can view the figures of all monitoring metrics.
    Figure 1 Viewing monitoring metrics
  4. To view the monitoring curve in a longer time range, click Full Image to view a chart in a bigger view.
    Figure 2 Zoomed in graph
  5. The system allows you to select a fixed time range or use automatic refresh.
    1. Fixed time ranges include Last 1 hour, Last 3 hours, Last 12 hours, Last 24 hours, and Last 7 days.
