Upgrading a Graph
Because the GES software is upgraded continuously, graphs of earlier versions can also be upgraded to the new version.
The procedure is as follows:
- Log in to the GES management console and choose Graph Management from the navigation pane on the left.
 - Locate the target graph in the graph list and choose More > Upgrade in the Operation column.
 - In the displayed dialog box, select a version from the Version List and determine whether to select Forcible Upgrade.
    If Forcible Upgrade is selected, all in-progress tasks will be interrupted. Exercise caution when performing this operation.
 - Click OK. The graph status changes to Upgrading. Wait several minutes, the status will become Running after the upgrade is successful.
    If the upgrade fails, the graph automatically rolls back to the source version.
