All Shortest Paths
Overview
The All Shortest Paths algorithm is used to find all shortest paths between two nodes in a graph.
Application Scenarios
This algorithm applies to scenarios such as path design and network planning.
Parameter Description
Table 1 All Shortest Paths algorithm parameters
Mandatory
Type
Value Range
Default Value
source
Yes
Enter the source ID of a path.
String
target
Yes
Enter the target ID of a path.
String
directed
No
Whether to consider the edge direction
Bool
true or false
false
Precautions
None
Example
Set parameters source to Lee, target to Alice, and directed to false. The calculation result is displayed on the canvas and the JSON result is displayed in the query result area.
