Node2vec
Overview
By invoking the Word2vec algorithm, the Node2vec algorithm maps nodes in the network to the Euclidean space, and uses vectors to represent the node characteristics.
The Node2vec algorithm generates random steps from each node using the rollback parameter P and forward parameter Q. It combines BFS and DFS. The rollback probability is proportional to 1/P, and the forward probability is proportional to 1/Q. Multiple random steps are generated to reflect the network structures.
Application Scenarios
This algorithm applies to scenarios such as node function similarity comparison, structural similarity comparison, and community clustering.
Parameter Description
Table 1 Node2vec algorithm parameters
Mandatory
Type
Value Range
Default Value
P
No
Rollback parameter
Double
Q
No
Forward parameter
Double
dim
No
Mapping dimension
Int
1 to 200, including 1 and 200
50
walkLength
No
Random walk length
Int
1 to 100, including 1 and 100
40
walkNumber
No
Number of random walk steps of each node.
Int
10
iterations
No
Number of iterations
Int
10
Precautions
None
Example
Set parameters P to 1, Q to 0.3, dim to 3, walkLength to 20, walkNumber to 10, and iterations to 40 to obtain the three-dimensional vector display of each node.
