Closeness Centrality
Overview
Closeness centrality of a node is a measure of centrality in a network, calculated as the reciprocal of the sum of the length of the shortest paths between the node and all other reachable nodes in a graph. It can be used to measure the time for transmitting information from this node to other nodes. The bigger the node's Closeness Centrality is, the more central the location of the node will be.
Application Scenarios
This algorithm is used in key node mining in social networking.
Parameter Description
        Parameter  |
        Mandatory  |
        Description  |
        Type  |
        Value Range  |
        Default Value  |
        source  |
        Yes  |
        Enter the ID of the node to be calculated.  |
        String  |
Example
Set parameter source to Lee to calculate the closeness centrality of the Lee node. The JSON result is displayed in the query result area.
