K-core
Overview
K-core is a classic graph algorithm used to calculate the number of cores of each node. The calculation result is one of the most commonly used reference values for determining the importance of a node so that the propagation capability of the node can be better understood.
Application Scenarios
This algorithm applies to scenarios such as community discovery and finance risk control.
Parameter Description
Table 1 K-core algorithm parameters
Mandatory
Type
Value Range
Default Value
k
Yes
Number of cores
The algorithm returns nodes whose number of cores is greater than or equal to k.
Int
Greater than or equal to 0
Precautions
None
Example
Set parameter k to 10. The sub-graph formed by nodes whose number of cores is greater than or equal to 10 in the calculation result is displayed on the canvas. The color of a node varies with the number of cores. The JSON result is displayed in the query result area.
