Deleting a Graph
If you have analyzed the graph data, you can delete the graph to release resources.
  Backups of a graph will be also deleted after the graph is deleted, and data cannot be recovered. Exercise caution when performing this operation.
The procedure is as follows:
- Log in to the GES management console.
 - In the navigation tree on the left, select Graph Management.
 - Locate the target graph in the graph list and choose More > Delete in the Operation column.
 - In the Delete Graph dialog box displayed, determine:
- Whether to delete the EIPs bound to the graph instance. If no EIPs are bound, this option is unavailable. If you do not select the EIPs, the EIPs are retained by default.
 - Whether to delete graph backups. By default, one automated backup and two manual backups are retained, occupying the backup quota. If you do not select the backups, the backups are retained by default.
 - Click OK.
