Updated on 2023-03-03 GMT+08:00
Stopping a Graph
If you do not need to use a graph, you can stop it. After the graph is stopped, you cannot access it.
Resources are not released after you stop the graph.
  1. Log in to the GES management console.
  2. In the navigation tree on the left, select Graph Management.
  3. Locate the target graph in the graph list and choose More > Stop in the Operation column.
  4. The graph status changes to Stopping. Wait several minutes. When the graph is successfully stopped, the graph status is switched to Stopped.
