Billing
Billing Items
EVS disks are billed based on the disk type, size, and usage duration.
- Billing starts: immediately after you have purchased EVS disks, regardless of whether they are attached or not.
- Billing ends: after a pay-per-use disk is successfully deleted.
Billing Modes
EVS disks are billed by disk capacity on a pay-per-use basis.
Pay-per-use is a postpaid payment model. EVS disks are billed by the second and settled by the hour. For a duration of less than an hour, the payment is based on the actual duration that the service was used for.
Billing Involved in Configuration Modifications
| Item | Pay-per-Use |
| Capacity change |
 Multiple pieces of billing records will be generated within a billing cycle (an hour) when an expansion succeeded. For example, if you expand the capacity of an EVS disk from 100 GB to 200 GB at 01:30:01, two pieces of billing records will be generated in billing cycle 01:00:00-02:00:00. One is the billing record generated for the 100 GB in 01:00:00-01:30:00, and the other is the billing record generated for the 200 GB in 01:30:01-02:00:00. |
