Partition and File System Extension Preparations (Linux)
Updated on 2022-12-20 GMT+08:00
Before extending the disk partition and file system, you must check the disk partition style and file system format, and then select the appropriate operation accordingly.
  1. To view the disk partition style, see the following methods:
  2. To select the appropriate operation, see Table 1.
    Table 1 Disk partition and file system extension scenarios
    Disk
    Method
    System disk
    Create a new MBR partition with the additional space.
    Creating a New MBR Partition
    Allocate the additional space to an existing MBR partition.
    Data disk
    Extending an Existing MBR Partition
    Create a new GPT partition with the additional space.
    Creating a New GPT Partition
    Allocate the additional space to an existing GPT partition.
    Extending an Existing GPT Partition
    SCSI data disk
    The maximum disk capacity that MBR supports is 2 TiB, and the disk space exceeding 2 TiB cannot be used.
    If your disk uses MBR and you need to expand the disk capacity to over 2 TiB, change the partition style from MBR to GPT. Ensure that the disk data has been backed up before changing the partition style because services will be interrupted and data on the disk will be cleared during this change.
Method 1: Check Partition Style and File System Format Using fdisk
  1. Run the following command to view all the disks attached to the server:
    lsblk
    Information similar to the following is displayed:
    [root@ecs-test-0001 ~]# lsblk
    NAME   MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
    vda    253:0    0   40G  0 disk
    └─vda1 253:1    0   40G  0 part /
    vdb    253:16   0  150G  0 disk
    └─vdb1 253:17   0  100G  0 part /mnt/sdc
    In this example, data disk /dev/vdb already has partition /dev/vdb1 before capacity expansion, and the additional 50 GiB added has not been allocated yet. Therefore, /dev/vdb has 150 GiB, and /dev/vdb1 has 100 GiB.
  2. Run the following command to view the current disk partition style:
    fdisk -l
    [root@ecs-test-0001 ~]# fdisk -l
    Disk /dev/vda: 42.9 GB, 42949672960 bytes, 83886080 sectors
    Units = sectors of 1 * 512 = 512 bytes
    Sector size (logical/physical): 512 bytes / 512 bytes
    I/O size (minimum/optimal): 512 bytes / 512 bytes
    Disk label type: dos
    Disk identifier: 0x000bcb4e
       Device Boot      Start         End      Blocks   Id  System
    /dev/vda1   *        2048    83886079    41942016   83  Linux
    Disk /dev/vdb: 161.1 GB, 161061273600 bytes, 314572800 sectors
    Disk identifier: 0x38717fc1
    /dev/vdb1            2048   209715199   104856576   83  Linux
    The value in the System column indicates the disk partition style. Value Linux indicates the MBR partition style. Value GPT indicates the GPT partition style.
    • If the disk partitions displayed are inconsistent with those obtained in 1, the partition that is not displayed uses the GPT partition style and has unallocated space. In this case, you cannot query all the partition information using the fdisk -l command. Go to Method 2: Check Partition Style and File System Format Using parted.
    • If the disk partitions displayed are consistent with those obtained in 1, continue with the following operations.
  3. Run the following command to view the partition's file system format:
    blkid Disk partition
    In this example, run the following command:
    blkid /dev/vdb1
    In the command output, the TYPE value is ext4, indicating that /dev/vdb1's file system format is ext4.
  4. Run the following command to view the file system status:
    ext*: e2fsck -n Disk partition
    xfs: xfs_repair -n Disk partition
    In this example, the ext4 file system is used. Therefore, run the following command:
    e2fsck -n /dev/vdb1
    [root@ecs-test-0001 ~]# e2fsck -n /dev/vdb1
    e2fsck 1.42.9 (28-Dec-2013)
    Warning!  /dev/vdb1 is mounted.
    Warning: skipping journal recovery because doing a read-only filesystem check.
    /dev/vdb1: clean, 11/6553600 files, 459544/26214144 blocks
    If the file system status is clean, the file system status is normal. Otherwise, rectify the faulty and then perform the capacity expansion.
    lsblk
  2. Run the following command and enter p to view the disk partition style:
    parted Disk
    For example, run the following command to view /dev/vdb's partition style:
    parted /dev/vdb
    [root@ecs-test-0001 ~]# parted /dev/vdb
    GNU Parted 3.1
    Using /dev/vdb
    Welcome to GNU Parted! Type 'help' to view a list of commands.
    (parted) p
    Error: The backup GPT table is not at the end of the disk, as it should be.  This might mean that another operating system believes the
    disk is smaller.  Fix, by moving the backup to the end (and removing the old backup)?
    Fix/Ignore/Cancel? Fix
    Warning: Not all of the space available to /dev/vdb appears to be used, you can fix the GPT to use all of the space (an extra 104857600
    blocks) or continue with the current setting?
    Fix/Ignore? Fix
    Model: Virtio Block Device (virtblk)
    Disk /dev/vdb: 161GB
    Sector size (logical/physical): 512B/512B
    Partition Table: gpt
    Disk Flags:
    Number  Start   End    Size   File system  Name  Flags
     1      1049kB  107GB  107GB  ext4         test
    (parted)
    In the command output, parameter Partition Table indicates the disk partition style. Value msdos indicates the MBR partition style, and value gpt indicates the GPT partition style.
    • If the following error information is displayed, enter Fix.
      The GPT partition table information is stored at the start of the disk. To reduce the risk of damage, a backup of the information is saved at the end of the disk. When you expand the disk capacity, the end of the disk changes accordingly. In this case, enter Fix to move the backup file of the information to new disk end.
    • If the following warning information is displayed, enter Fix.
      Fix/Ignore? Fix
      Enter Fix as prompted. The system automatically sets the GPT partition style for the additional space.
  3. Enter q and press Enter to exit parted.
