Updated on 2022-12-20 GMT+08:00
Deleting EVS Disks
If an EVS disk is no longer used, you can release the virtual resources by deleting the disk from the system.
- When you delete a disk, all the disk data including the snapshots created for this disk will be deleted. Exercise caution when performing this operation.
- A deleted disk cannot be recovered.
- Under Storage, click Elastic Volume Service.
The disk list page is displayed.
- In the disk list, locate the row that contains the target disk, click More in the Operation column, and choose Delete.
- (Optional) If multiple disks are to be deleted, select
in front of each disk and click Delete in the upper area of the list.
- In the displayed dialog box, confirm the information and click Yes.
