- What's New
- Function Overview
- Getting Started
User Guide
- Permissions Management
- Purchasing and Using an EVS Disk
- Attaching an Existing EVS Disk
- Viewing EVS Disk Details
- Changing the EVS Disk Type (OBT)
- Expanding EVS Disk Capacity
- Detaching and Deleting an EVS Disk
- Managing EVS Recycle Bin
Managing EVS Snapshots
- EVS Snapshot Overview
Using EVS Snapshots
- Creating an EVS Snapshot
- Rolling Back Disk Data from a Snapshot
- Creating a Disk from a Snapshot
- Enabling or Disabling Instant Snapshot Restore (for Snapshots in Commercial Use)
- Checking the EVS Snapshot Storage Usage (for Snapshots in Commercial Use)
- Checking EVS Snapshot Details
- Deleting an EVS Snapshot
- Managing Encrypted EVS Disks
- Managing Shared EVS Disks
- Managing EVS Disk Backups
- Managing EVS Transfers
- Managing EVS Tags
- Managing EVS Quotas
- Cloud Eye Monitoring
- Recording EVS Operations Using CTS
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- API Version Query
API
Disk Management
- Creating EVS Disks
- Updating an EVS Disk
- Querying Details About All EVS Disks
- Querying Details About an EVS Disk
- Expanding Capacity of an EVS Disk
- Deleting an EVS Disk
- Creating EVS Disks (Deprecated)
- Querying EVS Disks (Deprecated)
- Expanding Capacity of an EVS Disk (Deprecated)
- Unsubscribing from Yearly/Monthly EVS Disks
- Querying Details About All EVS Disks (Deprecated)
- Querying Details About an EVS Disk (Deprecated)
- Modifying QoS of an EVS Disk
- Snapshot Management
- Tag Management
- Task Management
Disk Management
Cinder API
Disk Management
- Querying EVS Disk Types
- Querying Details About an EVS Disk Type
- Querying Extension APIs
- Setting Bootable Flag for an EVS Disk
- Setting Read-Only Flag for an EVS Disk
- Exporting EVS Disk Data as an Image
- Attaching an EVS Disk (Deprecated)
- Detaching an EVS Disk (Deprecated)
- Reserving an EVS Disk (Deprecated)
- Canceling Reservation of an EVS Disk (Deprecated)
- Quota Management
- Disk Transfer Management
- Disk Metadata Management
- Snapshot Metadata Management
- API Version Query
- AZ Query
Disk Management
Out-of-Date APIs
- API
Cinder API
Disk Management
- Quota Management
- Querying AZs
Disk Management
- Appendix
- Change History
- SDK Reference
- Summary
General
- How Do I Start Using a Newly Purchased Disk?
- Can EVS Disks Be Used Directly for Storage?
- Can EVS Disks Be Used Alone?
- How Can I View My Disk Details?
- How Do I Change the Name of My Disk?
- Can I Change the AZ of My Disk?
- Can I Change the Disk Type, Device Type, or Sharing Attribute of My Disk?
- What Should I Do If an Error Occurs on My EVS Disk?
- How Can I Obtain ECS NIC Information?
- Why Do Some of My EVS Disks Not Have WWN Information?
- How Can I Migrate Data from an EVS Disk?
- What Are the Differences Between System Disks and Data Disks?
- Will I Lose My Disk Data If I Reinstall ECS OS, Change the OS, or Change the ECS Specifications?
- How Can I Export the Original Data After I Changed My Server OS from Windows to CentOS?
- What Are the Differences Between MBR and GPT Partition Styles?
- What Does the "reserveVolume" Trace Mean in CTS?
- How Can I Download My EVS Disk Data to a Local PC?
- How Can I Upload Files to My EVS Disk?
Billing
- How Can I Stop Being Billed for My Disk?
- Will I Be Billed If I Have Purchased an EVS Disk But Not Used It?
- How Can I Delete or Unsubscribe from a Yearly/Monthly Disk?
- Can I Recover My Disk Data If the Disk Is Unsubscribed from, Deleted by Mistake, or Released After the Retention Period Ends?
- Will My EVS Disk Be Unsubscribed or Deleted When I Unsubscribe from or Delete Its Server?
- Will I Be Billed for the Disks in the Recycle Bin?
- Why Can't I View the Attached Data Disk on the Server?
- Why Can't I Attach My Disk to a Server?
- Can I Attach a Disk to Multiple Servers?
- Can I Attach a Disk to a Server in a Different AZ?
- How Can I Add a Data Disk to an Existing Server?
- Can I Attach a Yearly/Monthly Disk to Another Server?
- Can I Attach Different Types of Disks to the Same Server?
- Can I Switch Between System Disks and Data Disks?
- What Should I Do If a Linux EVS Disk Is Attached to a Windows Server?
- Can I Attach an EVS Disk Purchased with a Yearly/Monthly Server to Another Yearly/Monthly Server?
- Can I Change the Function of a System Disk or Data Disk Purchased Along with a Server?
- How Do I Obtain My Disk Device Name in the ECS OS Using the Device Identifier Provided on the Console?
- How Can I View Data on My Disk If Its Yearly/Monthly Server Has Expired?
Capacity Expansion
- Can I Reduce or Temporarily Expand the Disk Capacity?
- What Are the Differences Between Expanding Capacity by Expanding an EVS Disk and Creating a New EVS Disk?
- Will My Disk Data Be Lost After I Expand the Disk Capacity?
- Can I Use Backups or Snapshots Created Before Capacity Expansion to Restore Data on Expanded Disks?
- Do I Need to Restart the Server After Expanding the Disk Capacity?
- Do I Need to Detach an EVS Disk Before Expanding Its Capacity?
- What Should I Do If My Disk Capacity Exceeds 2 TiB After Expansion?
- How Can I Allocate Newly Added Space to a New Partition?
- How Can I Allocate Newly Added Space to an Existing Partition?
- Why Did My Disk Capacity Remain Unchanged on the Server After Capacity Expansion?
- Why Can't I Expand Capacity for My Disk?
- How Do I Extend the File System of an Unpartitioned Data Disk in Linux?
- How Do I Extend the Root Partition of a Quickly Provisioned BMS?
- How Do I View the Disk Partition Style in Linux?
- Detachment
- Deletion
Capacity
- What Is the Maximum Capacity Supported for the System and Data Disks?
- What Should I Do If My Disk Starts to Run Out of Space?
- How Do I Clean Up My Disk Space on a Windows Server?
- What Can I Do If the Capacity of My Disk Reaches the Maximum But I Still Need More Space?
- What Should I Do If I Use fdisk to Initialize a Disk Larger Than 2 TiB and Then the Space in Excess of 2 TiB Cannot Be Displayed?
- How Can I View My Disk Usage?
- How Can I Monitor My Disk Usages?
- Can I Transfer the Data Disk Capacity to a System Disk?
- Why the Space of My New Disk Is Full After I Uploaded Only 500 MB of Files to the Disk?
Snapshot
- What Are the Typical Causes of a Snapshot Creation Failure?
- Does EVS Support Automatic Snapshot Creation?
- Can I Create Snapshots for Multiple Disks at a Time?
- How Is a Snapshot Created for My Disk?
- Why Can't I Roll Back My Disk Data from a Snapshot?
- Can I Roll Back Data from a Snapshot After Reinstalling the OS or Formatting a Disk?
- How Is the Snapshot Size Calculated?
- Do Snapshots Take Space on the Disk?
- Can I Perform Multiple Rollback Operations for a Snapshot?
- Can I Replicate Snapshots to Other Regions or Accounts?
- Why Can't I Find My Snapshot?
- Can I Use a Snapshot to Create a Disk and Roll Back Disk Data at Almost the Same Time?
Performance
- How Do I Test My Disk Performance?
- Why Does My Disk Performance Test Using Fio Have Incorrect Results?
- How Can I Handle a Slowdown in Disk Read/Write Speed or Increased I/Os?
- How Can I Improve My Disk Performance?
- Why My Disk's Read IOPS Can't Reach the Theoretical Maximum IOPS When the Disk I/O Usage Is Almost 100%?
- Sharing
- Backup
- Videos
- Glossary
More Documents
User Guide
- Overview
Getting Started
- Basic Operation Procedure
- Create an EVS Disk
- Attach an EVS Disk
Initialize an EVS Data Disk
- Introduction to Data Disk Initialization Scenarios and Partition Styles
- Initializing a Windows Data Disk (Windows Server 2008)
- Initializing a Windows Data Disk (Windows Server 2019)
- Initializing a Linux Data Disk (fdisk)
- Initializing a Linux Data Disk (parted)
- Initializing a Windows Data Disk Larger Than 2 TiB (Windows Server 2008)
- Initializing a Windows Data Disk Larger Than 2 TiB (Windows Server 2012)
- Initializing a Linux Data Disk Larger Than 2 TiB (parted)
- Disk Capacity Expansion
- Deleting EVS Disks
- Managing EVS Backups
- Managing EVS Snapshots
- Managing a Tag
- Viewing EVS Monitoring Data
- Auditing
FAQ
General
Capacity Expansion
- Can I Attach a Disk to a Server in Another AZ?
- Detachment
- Capacity
- Sharing
General
- Appendix
- Change History
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- API Version Query
- API v2
OpenStack Cinder API v2
EVS Disk
- Querying Details About All Disks
- Querying Details About a Disk
- Querying Details of Tenant Quotas
- Adding Metadata of an EVS Disk
- Querying Metadata of an EVS Disk
- Updating Metadata of an EVS Disk
- Querying One Piece of Metadata for an EVS Disk
- Updating One Piece of Metadata for an EVS Disk
- Deleting One Piece of Metadata for an EVS Disk
- Querying All AZs
EVS Disk Actions
EVS Snapshot
- Updating an EVS Snapshot
- Querying EVS Snapshots
- Querying Details About EVS Snapshots
- Querying Details About an EVS Snapshot
- Adding Metadata of an EVS Snapshot
- Querying Metadata of an EVS Snapshot
- Updating One Piece of Metadata for an EVS Snapshot
- Updating Metadata of an EVS Snapshot
- Querying One Piece of Metadata for an EVS Snapshot
- Deleting One Piece of Metadata for an EVS Snapshot
- EVS Disk Transfer
EVS Disk
- Out-of-Date APIs
- Appendix
- Change History
User Guide (Paris Region)
- Overview
Getting Started
- Process Overview
- Creating and Using an EVS Disk
- Attaching an Existing Disk
- Managing a Tag
- Changing EVS Disk Name
- Viewing EVS Monitoring Data (Agent Installed and Simplified Monitoring Metrics Used)
- Auditing
- Managing Quotas
FAQ
- Summary
General
- How Do I Start Using a Newly Created Disk?
- Billing
Capacity Expansion
- Can I Use Backups Created Before Capacity Expansion to Restore Data on Expanded Disks?
- Can I Change the Function of a System Disk or Data Disk Created Along with a Server?
- Detachment
- Deletion
Capacity
Performance
- How Can I Test My Disk Performance?
- How Can I Handle a Slowdown in Disk Read/Write Speed and Increased I/O?
- Sharing
- Backup
- Appendix
- Change History
API Reference (Paris Region)
- Before You Start
- API Overview
- Calling APIs
- Getting Started
APIs
- Disk Management
Tag Management
- Batch Deleting Tags of a Specified EVS Disk
- Batch Adding Tags for the Specified EVS Disk
- Obtaining All Tags of an EVS Resource Type
- Querying Tags of an EVS Disk
- Querying Details of EVS Disks by Tag
- Deleting the Tag of an EVS Resource by Key
- Querying the Number of EVS Disks by Tag
- Adding or Updating Tags for an EVS Resource (Deprecated)
- Batch Deleting Tags for an EVS Resource (Deprecated)
- Obtaining Tags of a Specified EVS Resource (Deprecated)
- Querying Tags of an EVS Resource by Key (Deprecated)
- Resetting Tags of an EVS Resource (Deprecated)
- Updating Tags of an EVS Resource by Key (Deprecated)
- Querying EVS Resources by Tag (Deprecated)
- Task Management
- EVS Replication Pair (Deprecated)
Replication Consistency Group (Deprecated)
- Creating a Replication Consistency Group (Deprecated)
- Deleting a Replication Consistency Group (Deprecated)
- Querying All Replication Consistency Groups (Deprecated)
- Querying Details About a Replication Consistency Group (Deprecated)
- Updating a Replication Consistency Group (Deprecated)
- Performing a Failover for a Replication Consistency Group (Deprecated)
- Synchronizing a Replication Consistency Group (Deprecated)
- Performing a Primary/Secondary Switchover for a Replication Consistency Group (Deprecated)
- Pausing a Replication Consistency Group (Deprecated)
- Reprotecting a Replication Consistency Group (Deprecated)
- Expanding EVS Disks in a Replication Consistency Group (Deprecated)
- EVS Replication Quota (Deprecated)
OpenStack Cinder APIs
Disk Management
- Quota Management
- AZ Query
- API Version Query
Disk Management
Out-of-Date APIs
EVS Disk
- Querying All AZs
- Querying Summary Information of EVS Disks
- Querying Details About a Disk (Deprecated)
- EVS Disk Actions
EVS Snapshot
- EVS Disk Transfer
EVS Disk
- Appendix
- Change History
- Overview
- Getting Started
- Expanding the EVS Disk Capacity
- Managing EVS Tags
FAQ
- Summary
General
- What EVS Disk Types Are Available?
Capacity Expansion
- How Do I Check the Disk Partition Style in Linux?
- How Do I Extend the Disk Partition and File System in Windows Server 2008?
- How Do I Extend the Disk Partition and File System in Linux?
- Detachment
- Deletion
Capacity
- How Can I View the Available Capacity of My Disk?
Snapshot
- Can I Modify Data in My EVS Snapshot?
- Performance
- Sharing
- Backup
- Change History
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- API Version Query
- APIs
EVS Disk
- Adding the Metadata for an EVS Disk
- Updating the Metadata of an EVS Disk
- Querying All AZs
EVS Disk Actions
EVS Snapshot
- Updating the Metadata of an EVS Snapshot
- EVS Disk Transfer
EVS Disk
- Out-of-Date APIs
- Appendix
- Change History
User Guide (Ankara Region)
- Overview
Getting Started
- Process Overview
- Managing Quotas
FAQ
General
- How Do I Start Using a Newly Disk?
Capacity Expansion
- Detachment
Capacity
Snapshot
- Can I Roll Back the Data from a Snapshot After Reinstalling the OS or Formatting the Disk?
- Can I Use a Snapshot to Create a Disk and Roll Back the Snapshot at Almost the Same Time?
- Sharing
General
- Appendix
- Change History
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- APIs
Disk Management
- Quota Management
- AZ Query
- API Version Query
Disk Management
Out-of-Date APIs
- API
EVS Disk
- Querying All AZs
- EVS Disk Actions
EVS Snapshot
- EVS Disk Transfer
EVS Disk
- Appendix
- Change History
User Guide
Create an EVS Disk
EVS disks can be used as system disks or data disks for servers.
- System disks can only be created together with servers and are automatically attached.
- A system disk can have a maximum of 1,024 GiB, and a data disk 32,768 GiB.
- Data disks that created together with servers are automatically attached.
- After servers are created, any data disks added on the cloud server console are automatically attached.
- After servers are created, any data disks added on the EVS console need to be manually attached.
This section describes how to separately create disks on the EVS console.
- Under Storage, click Elastic Volume Service.
The disk list page is displayed.
- Click Create Disk.
- Configure basic disk information according to Table 1.
Table 1 Disk parameters Parameter
Sub-Parameter
Example Value
Region
Mandatory
Resources are region-specific and cannot be used across regions through internal network connections. For low network latency and quick resource access, select the nearest region.
AZ
Mandatory
The availability zone (AZ) where you want to create the disk.
- Disks can only be attached to the servers in the same AZ.
- The AZ of a disk cannot be changed after the disk has been created.
Disk Specifications
Disk Type
Mandatory
The available disk types are as follows:
- High I/O
- Ultra-high I/O
When a disk is created from a snapshot, the disk type of the new disk will be consistent with that of the snapshot's source disk.
Ultra-high I/O
Disk Size (GiB)
Mandatory
The disk size. Only data disks can be created on the current page, and the disk size ranges from 10 GiB to 32,768 GiB.
- When you use a backup to create a disk, the disk capacity must be greater than or equal to the backup size. In the condition that you do not specify the disk capacity, if the backup size is smaller than 10 GiB, the default capacity 10 GiB will be used as the disk capacity; if the backup size is greater than 10 GiB, the disk capacity will be consistent with the backup size.
- When you use a snapshot to create a disk, the disk capacity must be greater than or equal to the snapshot size. In the condition that you do not specify the disk capacity, if the snapshot size is smaller than 10 GiB, the default capacity 10 GiB will be used as the disk capacity; if the snapshot size is greater than 10 GiB, the disk capacity will be consistent with the snapshot size.
100 GiB
Create from- Backup
- Snapshot
- Image
Optional- If you choose Create from Backup, the backup data is used to create the disk.
Click Create from and choose Backup. On the displayed page, select the target backup and click OK.
- One backup cannot be used for concurrent disk creation operations at the same time. For example, if you are creating disk A from a backup, this backup can be used to create another disk only after disk A has been created.
- If a disk is created from a backup of a system disk, the new disk can be used as a data disk only.
- If you choose Create from Snapshot, the snapshot data is used to create the disk.
Click Create from and choose Snapshot. On the displayed page, select the target snapshot and click OK.
- The disk type of the new disk is the same as that of the snapshot's source disk.
- The device type of the new disk is the same as that of the snapshot's source disk.
- The encryption attribute of the new disk is the same as that of the snapshot's source disk.
For details about the disk creation from snapshots, see Creating an EVS Disk from a Snapshot.
- If you choose Create from Image, the image data is used to create the disk.
Click Create from and choose Image. On the displayed page, select the target image and click OK.
- The device type of the new disk is the same as that of the image's source disk.
- Create from Backup: autobackup-001
- Create from Snapshot: snapshot-001
More
Advanced Settings- Share
- SCSI
Optional
- Share
If you select Share, a shared disk is created. A shared disk can be attached to up to 16 servers. If you do not select Share, a non-shared disk is created, and the disk can be attached to one server only.
If you select both SCSI and Share, a shared SCSI disk is created.
The sharing attribute of a disk cannot be changed after the disk has been created.
For details about shared EVS disks, see Managing Shared EVS Disks.
- SCSI
If you select SCSI, a SCSI disk is created. Such disks allow the server OS to directly access the underlying storage media and send SCSI commands to the disks. If you do not select SCSI, a VBD disk is created. That said, the disk device type is VBD, the default device type.
The device type of a disk cannot be changed after the disk has been created.
For details about the ECS types, OSs, and ECS software supported by SCSI EVS disks, see Device Types and Usage Instructions.
Tag
Optional
During the EVS disk creation, you can tag the EVS resources. Tags identify cloud resources for purposes of easy categorization and quick search.
A tag is composed of a key-value pair.- Key: Mandatory if the disk is going to be tagged
- Value: Optional if the disk is going to be tagged
- A maximum of 10 tags can be added for an EVS disk.
- Tag keys of the same EVS disk must be unique.
For details about tags, see the Tag Management Service User Guide.
Enterprise Project
Mandatory
When creating EVS disks, you can add the disks to an existing enterprise project.
An enterprise project facilitates project-level management and grouping of cloud resources and users. The default project is default.
default
Disk Name
Mandatory
- If you create disks individually, this parameter value is used as the actual disk name.
- If you create disks in a batch, this parameter value is used as the prefix of disk names, and one disk name will be composed of this parameter value and a four-digit number.
For example, if you create two disks and set volume for Disk Name, the EVS disk names will be volume-0001 and volume-0002.
Quantity
Optional
The number of disks to be created. The default value is set to 1, which means only one disk is created. Currently, you can create up to 100 disks at a time.
- If the disk is created from a backup, batch creation is not possible, and this parameter must be set to 1.
- If the disk is created from a snapshot, batch creation is not possible, and this parameter must be set to 1.
- Click Next.
- On the Details page, check the disk details.
- If you do not need to modify the specifications, click Submit.
- If you need to modify the specifications, click Previous.
- Go back to the disk list page and view the disk status.
When the disk status changes to Available, the disk is successfully created.
