Extending Disk Partitions and File Systems (Windows Server 2008)
After a disk has been expanded on the management console, the disk size is enlarged, but the additional space cannot be used directly.
In Windows, you must allocate the additional space to an existing partition or a new partition.
- For a system disk:
- If volume (C:) already exists, you can add the additional space to volume (C:) and use it as a system volume. For details, see System Disk: Add Additional Space to Volume (C:).
- If volume (C:) already exists, you can create a new volume such as volume (F:) with the additional space and use the new volume as a data volume. For details, see System Disk: Create New Volume (F:) with Additional Space.
- For a data disk:
- If volume (D:) already exists, you can add the additional space to volume (D:) and use it as a data volume. For details, see Data Disk: Add Additional Space to Volume (D:).
- If volume (D:) already exists, you can create a new volume such as volume (E:) with the additional space and use the new volume as a data volume. For details, see Data Disk: Create New Volume (E:) with Additional Space.
The method for allocating the additional space varies with the server OS. This section is used for reference only. For detailed operations and differences, see the corresponding OS documents.
Performing the expansion operations with caution. Misoperation may lead to data loss or exceptions. Therefore, you are advised to back up the disk data using CBR or snapshots before expansion. For details about using CBR, see Managing EVS Backups. For details about using snapshots, see Creating a Snapshot.
- You have expanded the disk capacity and attached the disk to a server on the management console. For details, see Expanding Capacity for an In-use EVS Disk or Expanding Capacity for an Available EVS Disk.
- You have logged in to the server.
- For how to log in to an ECS, see the Elastic Cloud Server User Guide.
- For how to log in to a BMS, see the Bare Metal Server User Guide.
In this example, the system disk has 50 GiB originally, and 22 GiB is added on the management console. The following procedure describes how to add this 22 GiB to volume (C:) on the server. After the operation is complete, volume (C:) will have 72 GiB of capacity and can be used as a system volume.
- On the desktop of the server, right-click Computer and choose Manage from the shortcut menu.
The Server Manager window is displayed.
- In the navigation tree, choose Storage > Disk Management.
The Disk Management window is displayed.
Figure 1 Disk Management (system disk)If you cannot view the additional space, right-click Disk Management and choose Refresh from the shortcut menu.
- On the Disk Management page, select the disk and volume that you want to extend. The current volume size and unallocated space are displayed.
- Right-click the target volume and choose Extend Volume.
Figure 2 Choosing Extend Volume
- On the displayed Extend Volume Wizard window, click Next.
Figure 3 Extend Volume Wizard
- In the text box to the right of Select the amount of space in MB, enter the amount of the additional space and click Next.
Figure 4 Selecting space
- Click Finish.
After the expansion succeeded, the partition size is larger than the original size.Figure 5 Capacity expansion succeeded
In this example, the system disk has 40 GiB originally, and 60 GiB is added on the management console. The following procedure describes how to use this 60 GiB to create a new volume, for example volume (F:), on the server. After the operation is complete, new volume (F:) has 60 GiB of capacity and can be used as a data volume.
The Disk Management window is displayed.Figure 6 Refresh (system disk)
- If you cannot view the additional space, right-click Disk Management and choose Refresh from the shortcut menu.
After the refresh, the additional space is displayed in the right area and is unallocated.
Figure 7 Unallocated disk space (system disk) - In the Unallocated area of Disk 0, right-click the blank area and choose New Simple Volume.
Figure 8 New Simple Volume (system disk)
- On the displayed New Simple Volume Wizard window, click Next.
Figure 9 New Simple Volume Wizard (system disk)
- On the displayed Specify Volume Size page, set Simple volume size in MB and click Next. In this example, the default size is used.
Figure 10 Specify Volume Size (system disk)
- On the displayed Assign Drive Letter and Path page, click Assign the following drive letter, select a drive letter, and click Next. In this example, drive letter F is selected.
Figure 11 Assign Driver Letter or Path (system disk)
- On the displayed Format Partition page, click Format this volume with the following settings, set parameters based on the requirements, and select Perform a quick format. Then, click Next.
Figure 12 Format Partition (system disk)
- Click Finish.
After the expansion succeeded, new volume (F:) is displayed.Figure 13 Completing the New Simple Volume Wizard (new volume F:)Figure 14 New Volume (F:)
In this example, the data disk has 100 GiB originally, and 50 GiB is added on the management console. The following procedure describes how to add this 50 GiB to volume (D:) on the server. After the operation is complete, volume (D:) has 150 GiB of capacity and can be used as a data volume.
The Disk Management window is displayed.Figure 15 Disk Management (data disk)
Figure 16 Choosing Extend Volume (Windows Server 2008)
Figure 17 Extend Volume Wizard (Windows Server 2008)
Figure 18 Selecting space (Windows Server 2008)
- Click Finish.
After the expansion succeeded, the partition size is larger than the original size.Figure 19 Capacity expansion succeeded (Windows Server 2008)
In this example, the data disk has 40 GiB originally, and 60 GiB is added on the management console. The following procedure describes how to use this 60 GiB to create a new volume, for example volume (E:), on the server. After the operation is complete, new volume (E:) has 60 GiB of capacity and can be used as a data volume.
The Disk Management window is displayed.Figure 20 Refresh (data disk)
Figure 21 Unallocated disk space (data disk) - In the Unallocated area of Disk 1, right-click the blank area and choose New Simple Volume.
Figure 22 New Simple Volume (data disk)
Figure 23 New Simple Volume Wizard (data disk)
Figure 24 Specify Volume Size (data disk)
- On the displayed Assign Drive Letter and Path page, click Assign the following drive letter, select a drive letter, and click Next. In this example, drive letter E is selected.
Figure 25 Assign Driver Letter or Path (data disk)
Figure 26 Format Partition (data disk)
- Click Finish.
After the expansion succeeded, new volume (E:) is displayed.Figure 27 Completing the New Simple Volume Wizard (new volume E:)Figure 28 New Volume (E:)
