Disk Types and Performance
EVS disks are classified based on the disk I/O performance. EVS disks differ in performance and price. Choose the disk type most appropriate for your applications.
EVS Performance
- IOPS: Number of read/write operations performed by an EVS disk per second
- Throughput: Amount of data read from and written into an EVS disk per second
- Read/write I/O latency: Minimum interval between two consecutive read/write operations on an EVS disk
| Parameter | High I/O | Ultra-high I/O |
| IOPS per GiB/EVS disk | 6 | 50 |
| Max. IOPS/EVS disk | 5,000 | 33,000 |
| Baseline IOPS/EVS disk | 1,200 | 1,500 |
| IOPS limit/EVS disk | Min. (5,000, 1,200 + 6 x Capacity) | Min. (33,000, 1,500 + 50 x Capacity) |
| IOPS burst limit/EVS disk | 5,000 | 16,000 |
| Max. throughput | 150 MiB/s | 350 MiB/s |
| API name
         This API name indicates the value of the volume_type parameter in the EVS API. It does not represent the type of the underlying hardware device. | SAS | SSD |
| Typical application scenarios | Mainstream applications requiring high performance and high reliability, such as large-scale development and test environments, web server logs, and enterprise applications. Typical enterprise applications include SAP applications, Microsoft Exchange, and Microsoft SharePoint. | Read/write-intensive applications that require ultra-high I/O and throughput, such as distributed file systems used in HPC scenarios or NoSQL and relational databases used in I/O-intensive scenarios. Typical databases include MongoDB, Oracle, SQL Server, MySQL, and PostgreSQL databases. |
Calculating Disk IOPS Limit
To calculate the IOPS limit of a disk, obtain the smaller value of the following two values:
- Max. IOPS/disk
- Baseline IOPS/disk + IOPS per GiB x Disk capacity
- If the disk capacity is 100 GiB, the disk IOPS limit is calculated as follows:
     Disk IOPS limit = Min. (33,000, 1,500 + 50 x 100) The disk IOPS limit is 6,500, the smaller value between 33,000 and 6,500.
- If the disk capacity is 1,000 GiB, the disk IOPS limit is calculated as follows:
     Disk IOPS limit = Min. (33,000, 1,500 + 50 x 1,000) The disk IOPS limit is 33,000, the smaller value between 33,000 and 51,500.
Disk Burst Capability and Principles
The burst capability allows a small-capacity disk to surpass the disk IOPS limit within a certain period of time. The IOPS limit indicates the performance of a single disk.
The burst capability is suitable for improving the server startup speed. Normally, system disks have small capacities. For example, if a 50-GiB ultra-high I/O disk does not have the burst capability, its IOPS limit can reach only 4,000 (1,500 + 50 x 50). However, if the disk has the burst capability, its IOPS limit can burst up to 16,000.
- If the disk capacity is 100 GiB, the disk IOPS limit is 6,500. In this case, the disk maximum IOPS can reach 16,000 in a certain duration.
- If the disk capacity is 1,000 GiB, the disk IOPS limit is 33,000. In this case, the disk IOPS limit already exceeds its IOPS burst limit (16,000), and the disk does not need the burst capability.
The burst IOPS consumption and reservation principles are described as follows:
The burst capability is implemented based on a token bucket. The number of initial tokens in the bucket is calculated as follows:
Number of initial tokens = Burst duration x IOPS burst limit
- Token production rate: This rate equals the disk IOPS limit, which is 6,500 tokens/s.
- Token consumption rate: This rate is calculated based on the I/O usage. Each I/O request consumes a token. The maximum consumption rate is 16,000 tokens/s, which is the larger value between the disk burst IOPS and IOPS limit.
Consumption principles
When the token consumption rate is greater than the production rate, the number of tokens decreases accordingly, and eventually the disk IOPS will be consistent with the token production rate (the IOPS limit). In this example, the disk can burst for approximately 3,032 seconds [28,800,000/(16,000 - 6,500)].
Reservation principles
When the token consumption rate is smaller than the production rate, the number of tokens increases accordingly, enabling the disk to regain the burst capability. In this example, if the disk is suspended for approximately 4,431 seconds (28,800,000/6,500), the token bucket will be filled up with tokens.
   As long as there are tokens in the token bucket, the disk will have the burst capability.
- When the number of tokens is greater than zero, the disk IOPS can exceed 6,500 and has the capability to reach 16,000, the IOPS burst limit.
- When the number of tokens is zero, the disk does not have the burst capability, and the maximum IOPS is 6,500.
- When the disk IOPS is less than 6,500, the number of tokens starts to increase, and the disk can regain the burst capability.
