- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Permissions Management
- Enterprise Routers
- Attachments
- Route Tables
- Associations
- Propagations
- Routes
Routing Control
Route Policies
- Route Policy Overview
- Creating a Route Policy
- Associating a Route Policy with an Enterprise Router
- Changing the Route Policy Associated with an Enterprise Router
- Disassociating a Route Policy from an Enterprise Router
- Modifying a Route Policy
- Viewing a Route Policy
- Deleting a Route Policy
- Adding a Policy Node to a Route Policy
- Modifying a Policy Node in a Route Policy
- Exporting Policy Nodes in a Route Policy
- Viewing a Policy Node in a Route Policy
- Deleting a Policy Node from a Route Policy
IP Prefix Lists
- IP Prefix List Overview
- Creating an IP Prefix List
- Modifying the Name of an IP Prefix List
- Viewing an IP Prefix List
- Deleting an IP Prefix List
- Adding a Prefix Rule to an IP Address Prefix List
- Modifying an IP Prefix Rule in an IP Prefix List
- Exporting Prefix Rules in an IP Prefix List
- Viewing a Prefix Rule in an IP Prefix List
- Deleting a Prefix Rule from an IP Prefix List
AS_Path Lists
- AS_Path List Overview
- Creating an AS_Path List
- Modifying the Name of an AS_Path List
- Viewing an AS_Path List
- Deleting an AS_Path List
- Adding an AS_Path Filter to an AS_Path List
- Exporting AS_Path Filters in an AS_Path List
- Viewing an AS_Path Filter in an AS_Path List
- Deleting an AS_Path Filter from an AS_Path List
Route Policies
- Sharing
- Flow Logs
- Monitoring and Auditing
- Tags
- Quotas
Best Practices
- Summary on Enterprise Router Best Practices
- Connecting VPCs Across Regions Using Enterprise Router and Central Network
- Using Enterprise Router to Isolate VPCs in the Same Region
- Using a Third-Party Firewall to Protect VPCs Connected by Enterprise Routers
- Enabling an On-Premises Data Center to Access Service VPCs Using an Enterprise Router and Transit VPC
- Setting Up a Hybrid Cloud Network Using Enterprise Router and Direct Connect Global DC Gateway
Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Direct Connect Connections (Global DC Gateway)
- Overview
- Network and Resource Planning
- Process of Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Direct Connect Connections (Global DC Gateway)
- Procedure for Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Direct Connect Connections (Global DC Gateway)
Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Active/Standby Direct Connect Connections (Global DC Gateway)
- Overview
- Process of Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Active/Standby Direct Connect Connections (Global DC Gateway)
- Procedure for Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Active/Standby Direct Connect Connections (Global DC Gateway)
- Setting Up a Hybrid Cloud Network Using Enterprise Router, VPN, and Direct Connect (Global DC Gateway)
- Setting Up a Hybrid Cloud Network Using Enterprise Router and Direct Connect (Virtual Gateway)
- Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Direct Connect Connections (Virtual Gateway)
- Setting Up a Hybrid Cloud Network Using Enterprise Router, VPN, and Direct Connect (Virtual Gateway)
- Allowing VPCs to Share an EIP to Access the Internet Using Enterprise Router and NAT Gateway
- Using Enterprise Router to Migrate the Network Set Up Through VPC Peering
- Using Enterprise Router to Migrate the Network Set Up Through Direct Connect (Global DC Gateway)
- Using Enterprise Router and Central Network to Migrate the Network Set Up Through a Cloud Connection
- API Reference
- FAQs
More Documents
- Getting Started
- Attachments
- Route Tables
- Associations
- Propagations
- Routes
- Sharing
- Flow Logs
- Monitoring
- Interconnecting with CTS
- Tags
- Quotas
- FAQ
- Change History
User Guide (Ankara Region)
- Getting Started
- Attachments
- Route Tables
- Associations
- Propagations
- Routes
- Sharing
- Flow Logs
- Monitoring
- Quotas
- FAQ
- Change History
- API Reference (Ankara Region)
Help Center/
Enterprise Router/
User Guide (ME-Abu Dhabi Region)/
Attachments/
Virtual Gateway Attachments/
Creating a Virtual Gateway Attachment
Attach a Direct Connect virtual gateway to an enterprise router to set up a hybrid cloud network using Direct Connect and Enterprise Router.
Create a virtual gateway attachment to an enterprise router. To create a virtual gateway, refer to "Establishing Network Connectivity" in the Direct Connect User Guide.
Parent topic: Virtual Gateway Attachments
