Deleting a VPN Gateway Attachment
This section describes how to delete a VPN gateway attachment from an enterprise router.
Notes and Constraints
- Deleting a VPC attachment will also delete its associations, propagations, and propagated routes in the route table.
- If flow logging is enabled for a VPC attachment, flow logging will be disabled, but collected flow logs will not be deleted.
- Click
in the upper left corner and select the desired region and project.
- Click Service List and choose Networking > Enterprise Router.
The Enterprise Router homepage is displayed.
- Search for the target enterprise router by name.
- Go to the Attachments tab using either of the following methods:
- In the upper right corner of the enterprise router, click Manage Attachment.
- Click the enterprise router name and click Attachments.
A VPN gateway attachment cannot be directly deleted on the Attachments tab.
A VPN gateway attachment will be automatically deleted after you perform the following operations to delete its VPN connections, unbind the EIP from the VPN gateway, and delete the VPN gateway.
- Locate the target VPN gateway attachment and click the attached resource.
Example: vpngw-demo
The VPN gateway attachment details page is displayed.
- On the attachment details page, click
in the upper left corner.
The VPN gateway list is displayed.
- In the VPN gateway list, locate the target VPN gateway, click More in the Operation column, and click Delete.
A confirmation dialog box is displayed.
- Click Yes.
A deleted VPN gateway cannot be recovered.
