- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Permissions Management
- Enterprise Routers
- Attachments
- Route Tables
- Associations
- Propagations
- Routes
Routing Control
Route Policies
- Route Policy Overview
- Creating a Route Policy
- Associating a Route Policy with an Enterprise Router
- Changing the Route Policy Associated with an Enterprise Router
- Disassociating a Route Policy from an Enterprise Router
- Modifying a Route Policy
- Viewing a Route Policy
- Deleting a Route Policy
- Adding a Policy Node to a Route Policy
- Modifying a Policy Node in a Route Policy
- Exporting Policy Nodes in a Route Policy
- Viewing a Policy Node in a Route Policy
- Deleting a Policy Node from a Route Policy
IP Prefix Lists
- IP Prefix List Overview
- Creating an IP Prefix List
- Modifying the Name of an IP Prefix List
- Viewing an IP Prefix List
- Deleting an IP Prefix List
- Adding a Prefix Rule to an IP Address Prefix List
- Modifying an IP Prefix Rule in an IP Prefix List
- Exporting Prefix Rules in an IP Prefix List
- Viewing a Prefix Rule in an IP Prefix List
- Deleting a Prefix Rule from an IP Prefix List
AS_Path Lists
- AS_Path List Overview
- Creating an AS_Path List
- Modifying the Name of an AS_Path List
- Viewing an AS_Path List
- Deleting an AS_Path List
- Adding an AS_Path Filter to an AS_Path List
- Exporting AS_Path Filters in an AS_Path List
- Viewing an AS_Path Filter in an AS_Path List
- Deleting an AS_Path Filter from an AS_Path List
Route Policies
- Sharing
- Flow Logs
- Monitoring and Auditing
- Tags
- Quotas
Best Practices
- Summary on Enterprise Router Best Practices
- Connecting VPCs Across Regions Using Enterprise Router and Central Network
- Using Enterprise Router to Isolate VPCs in the Same Region
- Using a Third-Party Firewall to Protect VPCs Connected by Enterprise Routers
- Enabling an On-Premises Data Center to Access Service VPCs Using an Enterprise Router and Transit VPC
- Setting Up a Hybrid Cloud Network Using Enterprise Router and Direct Connect Global DC Gateway
Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Direct Connect Connections (Global DC Gateway)
- Overview
- Network and Resource Planning
- Process of Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Direct Connect Connections (Global DC Gateway)
- Procedure for Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Direct Connect Connections (Global DC Gateway)
Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Active/Standby Direct Connect Connections (Global DC Gateway)
- Overview
- Process of Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Active/Standby Direct Connect Connections (Global DC Gateway)
- Procedure for Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Active/Standby Direct Connect Connections (Global DC Gateway)
- Setting Up a Hybrid Cloud Network Using Enterprise Router, VPN, and Direct Connect (Global DC Gateway)
- Setting Up a Hybrid Cloud Network Using Enterprise Router and Direct Connect (Virtual Gateway)
- Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Direct Connect Connections (Virtual Gateway)
- Setting Up a Hybrid Cloud Network Using Enterprise Router, VPN, and Direct Connect (Virtual Gateway)
- Allowing VPCs to Share an EIP to Access the Internet Using Enterprise Router and NAT Gateway
- Using Enterprise Router to Migrate the Network Set Up Through VPC Peering
- Using Enterprise Router to Migrate the Network Set Up Through Direct Connect (Global DC Gateway)
- Using Enterprise Router and Central Network to Migrate the Network Set Up Through a Cloud Connection
- API Reference
- FAQs
More Documents
- Getting Started
- Attachments
- Route Tables
- Associations
- Propagations
- Routes
- Sharing
- Flow Logs
- Monitoring
- Interconnecting with CTS
- Tags
- Quotas
- FAQ
- Change History
User Guide (Ankara Region)
- Getting Started
- Attachments
- Route Tables
- Associations
- Propagations
- Routes
- Sharing
- Flow Logs
- Monitoring
- Quotas
- FAQ
- Change History
- API Reference (Ankara Region)
Show all
Viewing Details About a Flow Log
This section describes how to view details about a flow log, including the attachment ID, source/destination address, source/destination port, data packet size, and packet quantity.
Flow logs are generated every 10 minutes. After creating a VPC flow log, you need to wait about 10 minutes before you can view the flow log record.
- Click
in the upper left corner and select the desired region and project.
- Click Service List and choose Networking > Enterprise Router.
The Enterprise Router homepage is displayed.
- Search for the target enterprise router by name.
- Click the enterprise router name and click Flow Logs.
The flow log list page is displayed.
- Locate the target flow log and click View Log Record in the Operation column.
The LTS console is displayed.
- View details about the flow log.
Flow log format:
<version> <project_id> <resource_id> <instance_id> <srcaddr> <dstaddr> <srcport> <dstport> <protocol> <packets> <bytes> <start> <end> <direct>
Example 1:
1 0605768ad980d5762f8ac010b919754c 9e00a67c-b21e-435f-9da6-20004b8392e9 a5cbd16c-7d99-4000-8f14-526ec48298ce 1.1.1.1 192.168.1.199 0 0 1 229 22442 1664007127 1664007727 ingress
Example 2:
1 0605768ad980d5762f8ac010b919754c 9e00a67c-b21e-435f-9da6-20004b8392e9 a5cbd16c-7d99-4000-8f14-526ec48298ce 192.168.1.199 1.1.1.1 8 0 1 229 22442 1664007127 1664007727 egress
Table 1 describes the flow log parameters.
Table 1 Enterprise router flow log parameters Parameter
Example
version
Flow log version
project_id
Project ID
5f67944957444bd6bb4fe3b367de8f3d
resource_id
ID of the attachment that the traffic is generated for
10a163ee-6efa-4e4d-9937-ead59f308497
instance_id
Enterprise router ID
srcaddr
Source IP address
192.168.0.154
dstaddr
Destination IP address
192.168.3.25
srcport
Source port
38929
dstport
Destination port
53
protocol
Internet Assigned Numbers Authority (IANA) protocol number of the traffic
For more information, see Internet Protocol Numbers.
17
packets
Number of data packets during the flow log capture
bytes
Size of the data packet during the flow log capture
96
start
The time when the capture started, in Unix seconds
1548752136
end
The time when the capture ended, in Unix seconds
1548752736
direct
Traffic direction
- ingress: traffic going in to the attachment
- egress: traffic going out of the attachment
egress
