- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Permissions Management
- Enterprise Routers
- Attachments
- Route Tables
- Associations
- Propagations
- Routes
Routing Control
Route Policies
- Route Policy Overview
- Creating a Route Policy
- Associating a Route Policy with an Enterprise Router
- Changing the Route Policy Associated with an Enterprise Router
- Disassociating a Route Policy from an Enterprise Router
- Modifying a Route Policy
- Viewing a Route Policy
- Deleting a Route Policy
- Adding a Policy Node to a Route Policy
- Modifying a Policy Node in a Route Policy
- Exporting Policy Nodes in a Route Policy
- Viewing a Policy Node in a Route Policy
- Deleting a Policy Node from a Route Policy
IP Prefix Lists
- IP Prefix List Overview
- Creating an IP Prefix List
- Modifying the Name of an IP Prefix List
- Viewing an IP Prefix List
- Deleting an IP Prefix List
- Adding a Prefix Rule to an IP Address Prefix List
- Modifying an IP Prefix Rule in an IP Prefix List
- Exporting Prefix Rules in an IP Prefix List
- Viewing a Prefix Rule in an IP Prefix List
- Deleting a Prefix Rule from an IP Prefix List
AS_Path Lists
- AS_Path List Overview
- Creating an AS_Path List
- Modifying the Name of an AS_Path List
- Viewing an AS_Path List
- Deleting an AS_Path List
- Adding an AS_Path Filter to an AS_Path List
- Exporting AS_Path Filters in an AS_Path List
- Viewing an AS_Path Filter in an AS_Path List
- Deleting an AS_Path Filter from an AS_Path List
Route Policies
- Sharing
- Flow Logs
- Monitoring and Auditing
- Tags
- Quotas
Best Practices
- Summary on Enterprise Router Best Practices
- Connecting VPCs Across Regions Using Enterprise Router and Central Network
- Using Enterprise Router to Isolate VPCs in the Same Region
- Using a Third-Party Firewall to Protect VPCs Connected by Enterprise Routers
- Enabling an On-Premises Data Center to Access Service VPCs Using an Enterprise Router and Transit VPC
- Setting Up a Hybrid Cloud Network Using Enterprise Router and Direct Connect Global DC Gateway
Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Direct Connect Connections (Global DC Gateway)
- Overview
- Network and Resource Planning
- Process of Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Direct Connect Connections (Global DC Gateway)
- Procedure for Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Direct Connect Connections (Global DC Gateway)
Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Active/Standby Direct Connect Connections (Global DC Gateway)
- Overview
- Process of Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Active/Standby Direct Connect Connections (Global DC Gateway)
- Procedure for Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Active/Standby Direct Connect Connections (Global DC Gateway)
- Setting Up a Hybrid Cloud Network Using Enterprise Router, VPN, and Direct Connect (Global DC Gateway)
- Setting Up a Hybrid Cloud Network Using Enterprise Router and Direct Connect (Virtual Gateway)
- Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Direct Connect Connections (Virtual Gateway)
- Setting Up a Hybrid Cloud Network Using Enterprise Router, VPN, and Direct Connect (Virtual Gateway)
- Allowing VPCs to Share an EIP to Access the Internet Using Enterprise Router and NAT Gateway
- Using Enterprise Router to Migrate the Network Set Up Through VPC Peering
- Using Enterprise Router to Migrate the Network Set Up Through Direct Connect (Global DC Gateway)
- Using Enterprise Router and Central Network to Migrate the Network Set Up Through a Cloud Connection
- API Reference
- FAQs
More Documents
- Getting Started
- Attachments
- Route Tables
- Associations
- Propagations
- Routes
- Sharing
- Flow Logs
- Monitoring
- Interconnecting with CTS
- Tags
- Quotas
- FAQ
- Change History
User Guide (Ankara Region)
- Getting Started
- Attachments
- Route Tables
- Associations
- Propagations
- Routes
- Sharing
- Flow Logs
- Monitoring
- Quotas
- FAQ
- Change History
- API Reference (Ankara Region)
Show all
Step 1: Plan Networks and Resources
- Network Planning: Plan CIDR blocks of VPCs and subnets, and route tables of VPCs and the enterprise router.
- Resource Planning: Plan the quantity, names, and parameters of cloud resources, including VPCs, ECSs, and the enterprise router.
Network Planning
Figure 1 and Table 2 show the network planning and its description for communications among VPCs in the same region.
Scenario |
Description |
Request from VPC 1 to VPC 3 |
Response from VPC 3 to VPC 1 |
Resource |
Description |
VPC |
Enterprise router |
After Default Route Table Association and Default Route Table Propagation are enabled and a VPC attachment is created, the system will automatically:
ECS |
The four ECSs are in different VPCs. If the ECSs are associated with different security groups, add rules to their security groups to allow access to each other. |
Destination |
Next Hop |
Route Type |
10.0.0.0/8 |
Enterprise router |
Static route: Custom |
172.16.0.0/12 |
Enterprise Router |
192.168.0.0/16 |
Enterprise Router |
- If you enable Auto Add Routes when creating a VPC attachment, you do not need to manually add static routes to the VPC route table. Instead, the system automatically adds routes (with this enterprise router as the next hop and 10.0.0.0/8, 172.16.0.0/12, and 192.168.0.0/16 as the destinations) to all route tables of the VPC.
- If an existing route in the VPC route tables has a destination to 10.0.0.0/8, 172.16.0.0/12, or 192.168.0.0/16, the routes will fail to be added. In this case, do not to enable Auto Add Routes. After the attachment is created, manually add routes.
- Do not set the destination of a route (with an enterprise router as the next hop) to 0.0.0.0/0 in the VPC route table. If an ECS in the VPC has an EIP bound, the VPC route table will have a policy-based route with 0.0.0.0/0 as the destination, which has a higher priority than the route with the enterprise router as the next hop. In this case, traffic is forwarded to the EIP and cannot reach the enterprise router.
Destination |
Next Hop |
Route Type |
VPC 1 CIDR block: 192.168.0.0/16 |
VPC 1 attachment: er-attach-01 |
Propagated route |
VPC 2 CIDR block: 172.16.0.0/16 |
VPC 2 attachment: er-attach-02 |
Propagated route |
VPC 3 CIDR block: 10.1.0.0/16 |
VPC 3 attachment: er-attach-03 |
Propagated route |
VPC 4 CIDR block: 10.2.0.0/16 |
VPC 4 attachment: er-attach-04 |
Propagated route |
Resource Planning
The following resource details are only examples. You can modify them as required.
- One enterprise router.
Table 5 Enterprise router details Enterprise Router Name
ASN
Association Route Table
Propagation Route Table
er-test-01
64512
Enable
Enable
Default route table
Default route table
er-attach-01
er-attach-02
er-attach-03
er-attach-04
- Four VPCs, each with a unique CIDR block.
Table 6 VPC details VPC Name
VPC CIDR Block
Subnet Name
Subnet CIDR Block
vpc-demo-01
192.168.0.0/16
subnet-demo-01
192.168.1.0/24
Default route table
vpc-demo-02
172.16.0.0/16
subnet-demo-02
172.16.1.0/24
Default route table
vpc-demo-03
10.1.0.0/16
subnet-demo-03
10.1.1.0/24
Default route table
vpc-demo-04
10.2.0.0/16
subnet-demo-04
10.2.1.0/24
Default route table
- Four ECSs in four different VPCs.
Table 7 ECS details ECS
VPC
Subnet
Security Group
Private IP Address
ecs-demo-01
Public image:
EulerOS 2.5 6
vpc-demo-01
subnet-demo-01
sg-demo (general-purpose web server)
192.168.1.12
ecs-demo-02
vpc-demo-02
subnet-demo-02
172.16.1.189
ecs-demo-03
vpc-demo-03
subnet-demo-03
10.1.1.105
ecs-demo-04
vpc-demo-04
subnet-demo-04
10.2.1.83
