Deleting a Propagation from a Route Table
This section describes how to delete a propagation from the route table of an enterprise router.
Notes and Constraints
Propagated routes are learned through propagation. Deleting a propagation will also delete the propagated routes.
- Click
in the upper left corner and select the desired region and project. - Click Service List and choose Networking > Enterprise Router.
The Enterprise Router homepage is displayed.
- Search for the target enterprise router by name.
- Go to the Route Tables tab using either of the following methods:
- In the upper right corner of the enterprise router, click Manage Route Table.
- Click the enterprise router name and click Route Tables.
- Click the route table where you want to delete a propagation. On the Propagations tab, locate the propagation you want to delete and click Delete in the Operation column.
A confirmation dialog box is displayed.
- Click Yes.
A deleted propagation cannot be recovered.
