Help Center/
Enterprise Router/
User Guide (ME-Abu Dhabi Region)/
Associations/
Deleting an Association from a Route Table
Updated on 2024-04-19 GMT+08:00
This section describes how to delete an association from the route table of an enterprise router.
- Click
in the upper left corner and select the desired region and project. - Click Service List and choose Networking > Enterprise Router.
The Enterprise Router homepage is displayed.
- Search for the target enterprise router by name.
- Go to the Route Tables tab using either of the following methods:
- In the upper right corner of the enterprise router, click Manage Route Table.
- Click the enterprise router name and click Route Tables.
- Click the route table that you want to delete an association from. On the Associations tab, locate the association you want to delete and click Delete in the Operation column.
A confirmation dialog box is displayed.
- Click Yes.
A deleted association cannot be recovered.
Parent topic: Associations
