Association Overview
- Packet forwarding: Packets from the attachment are forwarded through the routes specified in the associated route table.
- Route propagation: The routes in the associated route tables are automatically propagated to the route table of the attachment.
Attachment Type |
Route Learning |
Way to Create Association |
Description |
VPC |
Not supported |
Each attachment can only be associated with one route table. Associations between attachments in Figure 1 are described as follows:
Virtual gateway |
Supported |
VPN gateway |
Supported |
