Configuring the TOA Plug-in
ELB provides customized strategies for managing service access. Before customizing these strategies, ELB needs to obtain the client's IP address contained in the access request. To obtain the IP addresses, you can install a TOA kernel module on backend servers.
This section provides detailed operations for you to compile the module in the OS if you use TCP to distribute incoming traffic.
The operations for Linux OSs with kernel version of 2.6.32 are different from those for Linux OSs with kernel version of 3.0 or later.
![](https://support.huaweicloud.com/intl/en-us/ae-ad-1-usermanual-elb/public_sys-resources/note_3.0-en-us.png)
- TOA does not support listeners using the UDP protocol.
- The module can work properly in the following OSs and the methods for installing other kernel versions are similar:
- CentOS 6.8 (kernel version 2.6.32)
- SUSE 11 SP3 (kernel version 3.0.76)
- CentOS 7/7.2 (kernel version 3.10.0)
- Ubuntu 16.04.3 (kernel version 4.4.0)
- Ubuntu 18.04 (Kernel version 4.15.0)
- OpenSUSE 42.2 (kernel version 4.4.36)
- CoreOS 10.10.5 (kernel version 4.9.16)
- Debian 8.2.0 (Kernel version 3.16.0)
- The development environment for compiling the module must be the same as that of the current kernel.
- VMs can access OS repositories.
- Users other than root must have sudo permissions.
- In the following operations, the Linux kernel version is 3.0 or later.
- Prepare the compilation environment.
During the installation, you need to download the required module development package from the Internet if it cannot be found in the source.
The following are operations for compiling the module in different Linux OSs. Choose appropriate operations as needed.
- CentOS
- Run the following command to install the GCC:
- Run the following command to install the make tool:
- Run the following command to install the module development package (the development package header and module library must have the same version as the kernel):
sudo yum install kernel-devel-`uname -r`
During the installation, you need to download the required module development package from the following address if it cannot be found in the source:
https://mirror.netcologne.de/oracle-linux-repos/ol7_latest/getPackage/
For example, to install 3.10.0-693.11.1.el7.x86_64, run the following command:
rpm -ivh kernel-devel-3.10.0-693.11.1.el7.x86_64.rpm
- Ubuntu and Debian
- SUSE
- Run the following command to install the module development package (the package header and module library must have the same version as the kernel):
- CoreOS
For CoreOS, the module will be compiled in a container, and it must be started before the module is compiled.
For detailed operations, see the CoreOS documentation. Obtain the documentation from the following link:
- CentOS
- Compile the module.
- Use the git tool and run the following command to download the module source code:
git clone https://github.com/Huawei/TCP_option_address.git
If the git tool is not installed, download the module source code from the following link:
- Run the following commands to enter the source code directory and compile the module:
make
If no warning or error code is prompted, the compilation was successful. Verify that the toa.ko file was generated in the current directory.
If error message "config_retpoline=y but not supported by the compiler, Compiler update recommended" is displayed, the GCC version is too early. Upgrade the GCC to a later version.
- Load the module.
- Run the following command to load the module:
- Run the following command to check the module loading and to view the kernel output information:
If TOA: toa loaded is displayed in the command output, the module has been loaded.
After compiling the CoreOS module in the container, copy it to the host system and then load it. The container for compiling the module shares the /lib/modules directory with the host system, so you can copy the module in the container to this directory, allowing the host system to use it.
- Set the script to enable it to automatically load the module.
To make the module take effect when the system starts, add the command for loading the module to your startup script.
You can use either of the following methods to automatically load the module:
- Add the command for loading the module to a customized startup script as required.
- Perform the following operations to configure a startup script:
- Create the toa.modules file in the /etc/sysconfig/modules/ directory. This file contains the module loading script.
The following is an example of the content in the toa.modules file.
#!/bin/sh
/sbin/modinfo -F filename /root/toa/toa.ko > /dev/null 2>&1
if [ $? -eq 0 ]; then
/sbin/insmod /root/toa/toa.ko
fi
/root/toa/toa.ko is the path of the module file. You need to replace it with their actual path.
- Run the following command to add execution permissions for the toa.modules startup script:
sudo chmod +x /etc/sysconfig/modules/toa.modules
If the kernel is upgraded, the current module will no longer match. Therefore, you need to compile the module again.
- Install the module on multiple nodes.
To load the module in the same OSs, copy the toa.ko file to VMs where the module is to be loaded and then perform the operations in 3.
After the module is successfully loaded, applications can obtain the real IP address contained in the request.
The OS of the node must have the same version as the kernel.
- Verify the module.
After the module is successfully installed, the source address can be directly obtained. The following provides an example for verification.
Run the following command to start a simple HTTP service on the backend server where Python is installed:
python -m SimpleHTTPServer port
The value of port must be the same as the port configured for the backend server, and the default value is 80.
Access the IP address of the load balancer from a client. Access logs on the server are as follows:
192.168.0.90 - - [06/Aug/2020 14:24:21] "GET / HTTP/1.1" 200 –
192.168.0.90 indicates the client's source IP address that is obtained by the backend server.
- In the following operations, the Linux kernel version is 2.6.32.
The TOA plug-in supports the OSs (CentOS 6.8 image) with a kernel of 2.6.32-xx. Perform the following steps to configure the module:
- Obtain the kernel source code package Linux-2.6.32-220.23.1.el6.x86_64.rs.src.tar.gz containing the module from the following link:
http://kb.linuxvirtualserver.org/images/3/34/Linux-2.6.32-220.23.1.el6.x86_64.rs.src.tar.gz
- Decompress the kernel source code package.
- Modify compilation parameters.
- Open the linux-2.6.32-220.23.1.el6.x86_64.rs folder.
- Edit the net/toa/toa.h file.
Change the value of #define TCPOPT_TOA200 to #define TCPOPT_TOA254.
- On the shell page, run the following commands:
sed -i 's/CONFIG_IPV6=m/CONFIG_IPV6=y/g' .config
echo -e '\n# toa\nCONFIG_TOA=m' >> .config
After the configuration, the IPv6 module is compiled into the kernel. TOA is compiled into a separate module and can be independently started and stopped.
- Edit Makefile.
You can add a description to the end of EXTRAVERSION =. This description will be displayed in uname -r, for example, -toa.
- Run the following command to compile the software package:
n indicates the number of vCPUs. For example, if there are four vCPUs, n can be set to 4.
- Run the following command to install the module:
The following information is displayed.
Figure 1 Installing the module - Run the following command to install the kernel:
Figure 2 Installing the kernel - Open the /boot/grub/grub.conf file and configure the kernel to start up when the system starts.
- Change the default startup kernel from the first kernel to the zeroth kernel by changing default=1 to default=0.
- Add the nohz=off parameter to the end of the line containing the vmlinuz-2.6.32-toa kernel. If nohz is not disabled, the CPU0 usage may be high, causing uneven stress.
Figure 3 Configuration file
- Save the modification and exit. Restart the OS.
During the restart, the system will load the vmlinuz-2.6.32-toa kernel.
- After the restart, run the following command to load the module:
You are advised to add the modprobe toa command to both the startup script and the system scheduled monitoring script.
Figure 4 Adding the modprobe toa commandAfter the module is loaded, query the kernel information.
Figure 5 Querying the kernel - Verify the module.
