Help Center/
Elastic Load Balance/
User Guide (ME-Abu Dhabi Region)/
Load Balancer/
Changing Load Balancer Settings
Updated on 2022-01-25 GMT+08:00
For public network load balancers, you can change their bandwidth as required.
- In the upper left corner of the page, click
and select the desired region and project. - Click Service List. Under Network, click Elastic Load Balance.
- Locate the target load balancer and click Modify Bandwidth in the Operation column.
- In the New Configuration area, change the bandwidth and click Next.
- Click Submit.
Parent topic: Load Balancer
