Checking Whether the Source Database Is Connected
MySQL Migration
| Check Item | Whether the source database is connected |
| Description | Check the connectivity and accuracy of the IP address, port number, username, and password of the source database. |
| Failure Cause and Handling Suggestion | Failure cause: The connection fails. |
| Failure cause: Incorrect username or password Handling suggestion: Check whether the input username and password for the connection test are correct. | |
| Failure cause: The database account does not allow remote connections. Handling suggestion: Run the following command to create a user that allows remote connections. After the migration, delete this user. CREATE USER 'Account' @ '%' IDENTIFIED BY 'Password' | |
| Failure cause: The SSL CA root certificate is invalid. Handling suggestion: Upload a valid SSL CA certificate. | |
| Failure cause: No SSL CA root certificate exists. Handling suggestion: Contact technical support. | |
| Failure cause: The database is unavailable. Handling suggestion: Contact technical support. |
