Overview
A record set is a collection of resource records that belong to the same domain name. A record set defines DNS record types and values.
       Operation  |
       Scenario  |
       Constraints  |
       View record set types supported by the DNS service and their configuration rules.  |
       None  |
       Add record sets for a domain name. For details, see Table 1.  |
       Modify, delete, and view record sets.  |
       Add a record set that matches all subdomains.  |
       Wildcard DNS resolution does not support NS record sets.  |
       Search for, modify, disable, and delete record sets on the Dashboard > Record Set page.  |
       None  |
Figure 1 shows the process for configuring a record set on the DNS console.
