Managing Private Zones
You can modify a private zone, delete a private zone, batch delete private zones, or view details about a private zone.
Modifying a Private Zone
Change the email address of the domain name administrator and description of the private zone.
For more information about the email address, see Why Was the Email Address Format Changed in the SOA Record?
- In the service list, choose Network > Domain Name Service.
The DNS console is displayed.
- In the navigation pane, choose Private Zones.
The Private Zones page is displayed.
- Click
in the upper left corner and select the desired region and project.
- Locate the private zone you want to modify and click Modify under Operation.
The Modify Private Zone dialog box is displayed.
- Change the email address or description of the zone as required.
- Click OK.
Deleting a Private Zone
Delete a private zone when you no longer need it. After a private zone is deleted, the domain name and its subdomains cannot be resolved by the DNS service.
Before you delete a private zone, back up all record sets in the private zone.
- Click
- Locate the private zone you want to delete and click Delete under Operation.
The Delete Private Zone dialog box is displayed.
- Click Yes.
Batch Deleting Private Zones
Delete multiple private zones at a time. After the private zones are deleted, domain names and their subdomains cannot be resolved by the DNS service.
Before you delete private zones, back up all record sets in the private zones.
- Select the private zones you want to delete and click Delete.
- In the Delete Private Zone dialog box, click Yes.
Viewing Details About a Private Zone
View details about a private zone, such as zone ID, operation time, tag, and TTL, on the Private Zones page.
- On the Dashboard page, click Private Zones under My Resources.
- Click
- Locate the private zone you want to view and click
before the zone name to view its details.
