- What's New
- Function Overview
- Getting Started
User Guide
- Public Zones
- Private Zones
- Record Sets
- PTR Records
- Intelligent Resolution
- Resolver
- Permissions Management
- Using CTS to Collect DNS Key Operations
- Access Logging
- Quota Adjustment
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
- APIs
- Examples
- Appendix
- SDK Reference
DNS Overview
- Will I Be Billed for the DNS Service?
- How Many Zones, PTR Records, and Record Sets Can I Create?
- What Are Huawei Cloud DNS Servers?
- What Are Huawei Cloud Private DNS Server Addresses?
- What Are the Differences Between Public and Private Domain Names?
- Does DNS Support IPv6?
- Does DNS Support Explicit Forwarding and Implicit Forwarding?
- Does DNS Support Dynamic Domain Name Resolution?
- Does DNS Support Wildcard Entries?
- What Is TTL?
- How Many Domain Name Levels Does DNS Support?
- How Are Zones Queried to Resolve a Domain Name?
- What Are the Priorities of Resolution Lines?
- Why Was the Email Address Format Changed in the SOA Record?
- What Is CAA?
- Why Should I Set Priority For an MX Record Set?
- Can DNS Point a Domain Name to a Specific Port?
- Invalid Domain Resolution
- Website Access Failures
Public Zones
- Why Is a Message Indicating Conflict with an Existing Record Set Displayed When I Add a Record Set?
- How Do I Handle the Conflict Between CNAME and MX Record Sets?
- How Do I Add Record Sets to Subdomains?
- Which IP Address Is Returned for the Domain Name If There Are Multiple IP Addresses in a Record Set?
- Can I Modify a Zone?
- Can DNS Translate a Domain Name to IP Addresses of On-premises Servers or Third-Party Servers?
- How Can Multiple Domain Names Be Linked to the Same Website?
- Configuring Weighted Routing
- Can DNS Resolve a Domain Name that Has Not Been Licensed?
- How Do I Change the DNS Servers of a Domain Name?
- How Do I Handle Inaccurate Scheduling Caused by the CNAME Record Set Cache in the Default Lines?
Private Zones
- How Do I Change Default DNS Servers of an ECS to Huawei Cloud Private DNS Servers?
- How Can I Access an ECS Using Its Host Name?
- How Can I Map the Private IP Address of an ECS to a Domain Name?
- How Can I Use a Private Domain Name to Route Internet Traffic?
- Can I Use Private Domain Names Across Regions?
- Do I Need to Register Private Domain Names?
- Will a Deleted VPC Be Automatically Disassociated from the Private Zone?
- Are Private DNS Server Addresses the Same for All Users?
- What Are the Restrictions on Concurrent Private DNS Queries?
- Reverse Resolution
- Domain Transfer
DNS Overview
- Videos
More Documents
- Overview
- Getting Started
- Private Zone
- Record Set
- PTR Record
- Key Operations Recorded by CTS
- Quota Adjustment
- FAQs
- Change History
- API Reference (ME-Abu Dhabi Region)
User Guide (Paris Region)
- Overview
- Getting Started
- Public Zones
- Private Zones
- Record Sets
- PTR Records
- Quota Adjustment
FAQ
DNS Overview
- What Are DNS Servers?
- Does DNS Support Explicit and Implicit URLs?
- What Is TTL?
- What Is CAA?
Public Zones
- What Can I Do If There Is Message Indicating that the Public Zone Already Exists?
Private Zones
- What Are the Restrictions on Concurrent Private DNS Requests?
DNS Overview
- Change History
- API Reference (Paris Region)
- Overview
- Getting Started
- Private Zone
- Record Set
- Quota Adjustment
DNS Overview
- How Many Zones and Record Sets Can I Create?
- What Are the Private DNS Servers Provided by the DNS Service?
- Private Zones
DNS Overview
- Change History
- API Reference (Kuala Lumpur Region)
- User Guide (Ankara Region)
- API Reference (Ankara Region)
- Glossary
Show all
Adding a CNAME Record Set
If you want to map one domain name to another, add a CNAME record set for the domain name.
For more details, see Record Set Types and Configuration Rules.
- You can leave the Name parameter blank when adding a CNAME record set.
- You cannot create a CNAME record set with the same name and resolution line as an NS record set.
- In the service list, choose Network > Domain Name Service.
The DNS console is displayed.
- In the navigation pane, choose Private Zones.
The zone list is displayed.
- Click
in the upper left corner and select the desired region and project.
- Click the zone name.
- Click Add Record Set.
The Add Record Set dialog box is displayed.
- Set required parameters based on Table 1.
Table 1 Parameters for adding a CNAME record set Parameter
Example Value
Name
Prefix of the domain name to be resolved.
For example, if the zone name is example.com, the domain name prefix can be as follows:
- www: The domain name is www.example.com, which is usually used for a website.
- Left blank: The domain name is example.com.
In some cases, you may need to set the record set name to the at sign (@). However, the at sign is not supported. Leave the Name blank.
- abc: The domain name is abc.example.com, a subdomain of example.com.
- mail: The domain name is mail.example.com, which is typically used for an email server.
- *: The domain name is *.example.com, which is a wildcard domain name, indicating all subdomains of example.com.
Left blank
Type
Type of the record set
If a message is displayed indicating that the record set you are trying to create exists, the record set conflicts with an existing record set.
CNAME – Map one domain to another
TTL (s)
Cache duration of the record set on a local DNS server, in seconds.
The value ranges from 1 to 2147483647, and the default is 300.
If your service address changes frequently, set TTL to a smaller value.
The default value is 300, which is, 5 minutes.
Value
Domain name alias. You can enter only one domain name.
webserver01.example.com
Tag
(Optional) Identifier of the record set.
Each tag contains a key and a value. You can add a maximum of 10 tags to a record set. This parameter is displayed when you expand Other Settings.
For details about tag key and value requirements, see Table 2.
example_key1
example_value1
(Optional) Supplementary information about the record set.
You can enter a maximum of 255 characters.
Table 2 Tag key and value requirements Parameter
Requirements
Example Value
Key
- Cannot be left blank.
- Must be unique for each resource.
- Can contain a maximum of 36 characters.
- Cannot start or end with a space or contain special characters =*<>\,|/
example_key1
Value
- Can contain a maximum of 43 characters.
example_value1
- Click OK.
- Switch back to the Record Sets page.
View the added record set in the record set list of the zone and ensure that the status of the record set is Normal.
