- What's New
- Function Overview
- Getting Started
User Guide
- Public Zones
- Private Zones
- Record Sets
- PTR Records
- Intelligent Resolution
- Resolver
- Permissions Management
- Using CTS to Collect DNS Key Operations
- Access Logging
- Quota Adjustment
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
- APIs
- Examples
- Appendix
- SDK Reference
DNS Overview
- Will I Be Billed for the DNS Service?
- How Many Zones, PTR Records, and Record Sets Can I Create?
- What Are Huawei Cloud DNS Servers?
- What Are Huawei Cloud Private DNS Server Addresses?
- What Are the Differences Between Public and Private Domain Names?
- Does DNS Support IPv6?
- Does DNS Support Explicit Forwarding and Implicit Forwarding?
- Does DNS Support Dynamic Domain Name Resolution?
- Does DNS Support Wildcard Entries?
- What Is TTL?
- How Many Domain Name Levels Does DNS Support?
- How Are Zones Queried to Resolve a Domain Name?
- What Are the Priorities of Resolution Lines?
- Why Was the Email Address Format Changed in the SOA Record?
- What Is CAA?
- Why Should I Set Priority For an MX Record Set?
- Can DNS Point a Domain Name to a Specific Port?
- Invalid Domain Resolution
- Website Access Failures
Public Zones
- Why Is a Message Indicating Conflict with an Existing Record Set Displayed When I Add a Record Set?
- How Do I Handle the Conflict Between CNAME and MX Record Sets?
- How Do I Add Record Sets to Subdomains?
- Which IP Address Is Returned for the Domain Name If There Are Multiple IP Addresses in a Record Set?
- Can I Modify a Zone?
- Can DNS Translate a Domain Name to IP Addresses of On-premises Servers or Third-Party Servers?
- How Can Multiple Domain Names Be Linked to the Same Website?
- Configuring Weighted Routing
- Can DNS Resolve a Domain Name that Has Not Been Licensed?
- How Do I Change the DNS Servers of a Domain Name?
- How Do I Handle Inaccurate Scheduling Caused by the CNAME Record Set Cache in the Default Lines?
Private Zones
- How Do I Change Default DNS Servers of an ECS to Huawei Cloud Private DNS Servers?
- How Can I Access an ECS Using Its Host Name?
- How Can I Map the Private IP Address of an ECS to a Domain Name?
- How Can I Use a Private Domain Name to Route Internet Traffic?
- Can I Use Private Domain Names Across Regions?
- Do I Need to Register Private Domain Names?
- Will a Deleted VPC Be Automatically Disassociated from the Private Zone?
- Are Private DNS Server Addresses the Same for All Users?
- What Are the Restrictions on Concurrent Private DNS Queries?
- Reverse Resolution
- Domain Transfer
DNS Overview
- Videos
More Documents
- Overview
- Getting Started
- Private Zone
- Record Set
- PTR Record
- Key Operations Recorded by CTS
- Quota Adjustment
- FAQs
- Change History
- API Reference (ME-Abu Dhabi Region)
User Guide (Paris Region)
- Overview
- Getting Started
- Public Zones
- Private Zones
- Record Sets
- PTR Records
- Quota Adjustment
FAQ
DNS Overview
- What Are DNS Servers?
- Does DNS Support Explicit and Implicit URLs?
- What Is TTL?
- What Is CAA?
Public Zones
- What Can I Do If There Is Message Indicating that the Public Zone Already Exists?
Private Zones
- What Are the Restrictions on Concurrent Private DNS Requests?
DNS Overview
- Change History
- API Reference (Paris Region)
- Overview
- Getting Started
- Private Zone
- Record Set
- Quota Adjustment
DNS Overview
- How Many Zones and Record Sets Can I Create?
- What Are the Private DNS Servers Provided by the DNS Service?
- Private Zones
DNS Overview
- Change History
- API Reference (Kuala Lumpur Region)
- User Guide (Ankara Region)
- API Reference (Ankara Region)
- Glossary
Help Center/
Domain Name Service/
User Guide (ME-Abu Dhabi Region) /
Private Zone/
Disassociating a VPC from a Private Zone
Disassociate a VPC from a private zone if you do not want the private domain name to be resolved in this VPC. If a private zone has only one VPC associated, you cannot disassociate the VPC.
If you do not intend to use private domain names, delete the private zone configured for it.
- In the service list, choose Network > Domain Name Service.
The DNS console is displayed.
- In the navigation pane, choose Private Zones.
The Private Zones page is displayed.
- Click
in the upper left corner and select the desired region and project.
- Locate the private zone from which a VPC is to be disassociated, select the VPC to be disassociated under Associated VPC, and click
on the right of the VPC.
Figure 1 Associated VPC - In the Disassociate VPC dialog box, click Yes.
Parent topic: Private Zone
