User Guide
- Preparatory Work
- Introducing the DLV Console
- How-Tos
- Managing Workspaces
- Creating Data Connections
- Creating Screens
- Developing Screens
- Managing Screens
- Managing Layers
Data Connection Management
- Data Connection Overview
- Using Static Data Sources
- Creating API Data Connections
- Creating CSV File Data Connections
- Creating Object Storage Service Data Connections
- Creating Data Warehouse Service Data Connections
- Creating Data Lake Insight Data Connections
- Creating MRS Hive Data Connections
- Creating MRS SparkSQL Data Connections
- Creating ClickHouse Data Connections
- Creating RDS for MySQL Data Connections
- Creating RDS for PostgreSQL Data Connections
- Creating RDS for SQL Server Data Connections
- Creating RDS for GaussDB Data Connections
- Creating GeminiDB Influx API Data Connections
- Creating Cloud Search Service Data Connections
- Creating DDM Data Connections
- Creating Oracle Data Connections
- Creating MySQL Data Connections
- Creating PostgreSQL Data Connections
- Creating SQL Server Data Connections
- Creating Elasticsearch Data Connections
- Editing Data Connections
- Searching for Data Connections
- Deleting Data Connections
- Managing Components
- Component Guide
- Screen Combination
- Integrating DLV into Third-Party Systems
- Change History
- Developer Guide
- API Reference
- What Is DLV Used For?
- Regions and AZs
- Can I Quickly Create a DLV Screen Using a Template?
- Can DLV Connect to Data Sources Through APIs?
- What Types of Data Connections Are Supported in DLV?
- How Do I Configure a CSV Data Source?
- How Do I Use the Interaction Function?
- What Can I Do If a Component Cannot Be Completely or Normally Displayed?
- How Do I Query Data Formats Supported by Different Components?
- What Can I Do When the WebGL Component Breaks Down?
More Documents
- Preparatory Work
- How-Tos
- Creating Screens
- Managing Screens
- Managing Layers
- Creating API Gateway Data Connections
- Creating a DAYU Data Connection
- Managing VPC Connections
- Component Guide
- What Is DLV?
- Regions and AZs
- How Many Screens Can I Create in DLV?
- API Reference (ME-Abu Dhabi Region)
- Developer Guide (ME-Abu Dhabi Region)
Basic Concepts
Regions and AZs
For more information, see Regions and AZs.
Project
A project is a collection of resources and a minimum authorization unit. Users' resources must be mounted to a project. Projects are used to isolate resources between different departments, different projects, or different environments, such as the R&D environment, test environment, and production environment, in the same project.
A workspace enables the administrator to manage user (member) permissions, resources, and underlying compute engines of DLV.
Each team can have an independent workspace.
You can manage workspaces, data connections, screens, combined screens, and applications only after being added to workspaces and assigned permissions.
In workspace management, the administrator can add other users to the workspace and set roles such as administrator, developer, analyst, and visitor preset by DLV for users to implement multi-role collaborative development.
Member and Role
A member is a user who has been granted permission to access or use the workspace created on the cloud. When adding a workspace member, you need to set a role.
A role has a predefined combination of permissions. Different roles are assigned different permissions. After a role is assigned to a member, the member has all the permissions of that role. Each member must have at least one role, but they can have multiple roles assigned at the same time.
A workspace role can be an administrator, developer, analyst, or visitor.
Data Source
A data source is where data comes from. DLV provides multiple types of data connection: static data, APIs, databases, CSV files, APIG, and OBS.
Component
A component is a basic configurable module used to create a screen. DLV supports the following types of components: regular charts, maps, media, text, relational networks, materials, interaction, and others.
Canvas
A canvas is an interface editor used to edit components of DLV. On a canvas, you can design page layout and match colors for components and associate data sources with charts. All applications are published only in the canvas.
Layer
A layer refers to the precise positioning of a component on a screen. It is similar to a slide that contains elements such as text or graphics and is then combined with other slides in sequence to produce the final effect of a page.
