User Guide
- Preparatory Work
- Introducing the DLV Console
- How-Tos
- Managing Workspaces
- Creating Data Connections
- Creating Screens
- Developing Screens
- Managing Screens
- Managing Layers
Data Connection Management
- Data Connection Overview
- Using Static Data Sources
- Creating API Data Connections
- Creating CSV File Data Connections
- Creating Object Storage Service Data Connections
- Creating Data Warehouse Service Data Connections
- Creating Data Lake Insight Data Connections
- Creating MRS Hive Data Connections
- Creating MRS SparkSQL Data Connections
- Creating ClickHouse Data Connections
- Creating RDS for MySQL Data Connections
- Creating RDS for PostgreSQL Data Connections
- Creating RDS for SQL Server Data Connections
- Creating RDS for GaussDB Data Connections
- Creating GeminiDB Influx API Data Connections
- Creating Cloud Search Service Data Connections
- Creating DDM Data Connections
- Creating Oracle Data Connections
- Creating MySQL Data Connections
- Creating PostgreSQL Data Connections
- Creating SQL Server Data Connections
- Creating Elasticsearch Data Connections
- Editing Data Connections
- Searching for Data Connections
- Deleting Data Connections
- Managing Components
- Component Guide
- Screen Combination
- Integrating DLV into Third-Party Systems
- Change History
- Developer Guide
- API Reference
- What Is DLV Used For?
- Regions and AZs
- Can I Quickly Create a DLV Screen Using a Template?
- Can DLV Connect to Data Sources Through APIs?
- What Types of Data Connections Are Supported in DLV?
- How Do I Configure a CSV Data Source?
- How Do I Use the Interaction Function?
- What Can I Do If a Component Cannot Be Completely or Normally Displayed?
- How Do I Query Data Formats Supported by Different Components?
- What Can I Do When the WebGL Component Breaks Down?
More Documents
- Preparatory Work
- How-Tos
- Creating Screens
- Managing Screens
- Managing Layers
- Creating API Gateway Data Connections
- Creating a DAYU Data Connection
- Managing VPC Connections
- Component Guide
- What Is DLV?
- Regions and AZs
- How Many Screens Can I Create in DLV?
- API Reference (ME-Abu Dhabi Region)
- Developer Guide (ME-Abu Dhabi Region)
Show all
Yes, DLV can connect to external data sources through APIs. Specifically, you need to drag a component to a screen, set Data Source Type to API on the Data tab, and enter a URL by which DLV connects to a data source and obtains data from it. If a cross-region issue occurs, set header information Access-Control-Allow-Origin at the peer end to grant a region access permission.
