User Guide
- Preparatory Work
- Introducing the DLV Console
- How-Tos
- Managing Workspaces
- Creating Data Connections
- Creating Screens
- Developing Screens
- Managing Screens
- Managing Layers
Data Connection Management
- Data Connection Overview
- Using Static Data Sources
- Creating API Data Connections
- Creating CSV File Data Connections
- Creating Object Storage Service Data Connections
- Creating Data Warehouse Service Data Connections
- Creating Data Lake Insight Data Connections
- Creating MRS Hive Data Connections
- Creating MRS SparkSQL Data Connections
- Creating ClickHouse Data Connections
- Creating RDS for MySQL Data Connections
- Creating RDS for PostgreSQL Data Connections
- Creating RDS for SQL Server Data Connections
- Creating RDS for GaussDB Data Connections
- Creating GeminiDB Influx API Data Connections
- Creating Cloud Search Service Data Connections
- Creating DDM Data Connections
- Creating Oracle Data Connections
- Creating MySQL Data Connections
- Creating PostgreSQL Data Connections
- Creating SQL Server Data Connections
- Creating Elasticsearch Data Connections
- Editing Data Connections
- Searching for Data Connections
- Deleting Data Connections
- Managing Components
- Component Guide
- Screen Combination
- Integrating DLV into Third-Party Systems
- Change History
- Developer Guide
- API Reference
- What Is DLV Used For?
- Regions and AZs
- Can I Quickly Create a DLV Screen Using a Template?
- Can DLV Connect to Data Sources Through APIs?
- What Types of Data Connections Are Supported in DLV?
- How Do I Configure a CSV Data Source?
- How Do I Use the Interaction Function?
- What Can I Do If a Component Cannot Be Completely or Normally Displayed?
- How Do I Query Data Formats Supported by Different Components?
- What Can I Do When the WebGL Component Breaks Down?
More Documents
- Preparatory Work
- How-Tos
- Creating Screens
- Managing Screens
- Managing Layers
- Creating API Gateway Data Connections
- Creating a DAYU Data Connection
- Managing VPC Connections
- Component Guide
- What Is DLV?
- Regions and AZs
- How Many Screens Can I Create in DLV?
- API Reference (ME-Abu Dhabi Region)
- Developer Guide (ME-Abu Dhabi Region)
Show all
DLV is specifically designed to surface valuable insights buried inside the constantly changing and complex data in a more intuitive and user-friendly way. It applies to different sectors including retailing, logistics, electric power, water conservancy, environmental protection, and transportation. With real-time data displayed on interactive screens, DLV helps users discover and diagnose service issues whenever they arise. The following lists some benefits that DLV will bring to you:
- DLV provides you various visual components. In addition to the regular charts optimized for service display, DLV provides irregular charts presenting topological relationships. In addition, DLV supports display of flying lines, heatmaps, regions, 3D maps, and 3D globe, and allows layering of geographical data. In addition, there are irregular charts presenting topological relationships available for you.
- DLV seamlessly integrates with cloud services, such as Data Warehouse Service (DWS), Data Lake Insight (DLI), Relational Database Service (RDS), and Object Storage Service (OBS), and supports local CSV files, online APIs, and the private cloud data of enterprises. By fully utilizing big data computing capability, DLV can meet real-time computing and monitoring requirements.
- DLV enables you to build screens only by drag-and-drop without programming and to create screens of different sizes by adapting to unconventional resolutions.
- DLV allows you to release and share your created screens. In this way, your data services can be externally displayed.
