Help Center/
      Data Lake Visualization/
        User Guide (ME-Abu Dhabi Region)/
        Component Guide/
        Media/
      FLV Stream Player
        Updated on 2025-01-22 GMT+08:00
FLV Stream Player
This section describes parameters of an FLV stream player.
  Figure 1 FLV stream player
 Pattern
- Size/Position
- Size: width and height of the component. Unit: pixel.
 - Position: position where the component is located in the canvas. Unit: pixel.
 - Adjust Volume: to adjust the video volume.
Data
   Figure 2 FLV video stream player - Data
  - url: public network address of the FLV video stream in the format of https://domain name/directory/file name.flv.
 - Data Source Type: to select the data source of the chart. Multiple data sources are provided for you to select. You need to add data sources first. For details, see Data Connection Overview.
 - Converter: Select a converter to convert data into the data that meets the display requirements. For details, see Using a Converter.
 - Automatic Update: If you select Automatic Update and set Update Interval, the data is automatically updated based on the interval.
 - Preview Result: Click Preview Result to view the information about the selected data source. You can click Update Query to manually update the component data when the data source changes.
Interaction
For details about whether the component supports the interaction function and how to use the interaction function, see Configuring Component Interaction.
   Parent topic: Media
