User Guide
- Preparatory Work
- Introducing the DLV Console
- How-Tos
- Managing Workspaces
- Creating Data Connections
- Creating Screens
- Developing Screens
- Managing Screens
- Managing Layers
Data Connection Management
- Data Connection Overview
- Using Static Data Sources
- Creating API Data Connections
- Creating CSV File Data Connections
- Creating Object Storage Service Data Connections
- Creating Data Warehouse Service Data Connections
- Creating Data Lake Insight Data Connections
- Creating MRS Hive Data Connections
- Creating MRS SparkSQL Data Connections
- Creating ClickHouse Data Connections
- Creating RDS for MySQL Data Connections
- Creating RDS for PostgreSQL Data Connections
- Creating RDS for SQL Server Data Connections
- Creating RDS for GaussDB Data Connections
- Creating GeminiDB Influx API Data Connections
- Creating Cloud Search Service Data Connections
- Creating DDM Data Connections
- Creating Oracle Data Connections
- Creating MySQL Data Connections
- Creating PostgreSQL Data Connections
- Creating SQL Server Data Connections
- Creating Elasticsearch Data Connections
- Editing Data Connections
- Searching for Data Connections
- Deleting Data Connections
- Managing Components
- Component Guide
- Screen Combination
- Integrating DLV into Third-Party Systems
- Change History
- Developer Guide
- API Reference
- What Is DLV Used For?
- Regions and AZs
- Can I Quickly Create a DLV Screen Using a Template?
- Can DLV Connect to Data Sources Through APIs?
- What Types of Data Connections Are Supported in DLV?
- How Do I Configure a CSV Data Source?
- How Do I Use the Interaction Function?
- What Can I Do If a Component Cannot Be Completely or Normally Displayed?
- How Do I Query Data Formats Supported by Different Components?
- What Can I Do When the WebGL Component Breaks Down?
More Documents
- Preparatory Work
- How-Tos
- Creating Screens
- Managing Screens
- Managing Layers
- Creating API Gateway Data Connections
- Creating a DAYU Data Connection
- Managing VPC Connections
- Component Guide
- What Is DLV?
- Regions and AZs
- How Many Screens Can I Create in DLV?
- API Reference (ME-Abu Dhabi Region)
- Developer Guide (ME-Abu Dhabi Region)
On this page
Show all
Help Center/
Data Lake Visualization/
User Guide (ME-Abu Dhabi Region)/
Component Guide/
Others/
Funnel Chart
Funnel Chart
This section describes parameters of a funnel chart.
Pattern
- Size/Position
- Size: width and height of the component. Unit: pixel.
- Position: position where the component is located in the canvas. Unit: pixel.
Figure 1 Funnel chart - Global Style
- Font: font type of the component text.
- Layout: layout of the component. The value can be Align left, Align right, or Align center.
- Data Sorting: data sorting of the component. The value can be Ascend, Descend, or Data sequence.
- Image Position: position of the component. Specific settings include Horizontal Moving, Top, and Bottom.
- Range
- Min. Value: to set the minimum value by entering a value or clicking
- Max. Value: to set the maximum value by entering a value or clicking
- Bottom Width: to set the bottom width of the component by entering a value or dragging
. A smaller value leads to a narrower bottom width.
- Top Width: to set the top width of the component by entering a value or dragging
. A smaller value leads to a wider top width.
- Value Tag
- Value Tag: to show or hide the value tag by clicking
or
- Text Style: text style of the value tag, including Font Size, Color, Font Width, and Position.
- Legend
- Legend: to show or hide legends by clicking
or
- Text Style: text style of the legend, including Font Size, Color, and Font Width.
- Layout: layout style of the legend, including Position, Left/Right Spacing, and Top/Bottom Spacing.
Data
For details about how to configure component data, see Configuring Component Data.
- value: value label displayed on each layer in the funnel chart.
- s: The s field is a data series field. Data is grouped based on the value of the s field.
- Add a data series: Click
next to s to add a data series.
- Configure a data series: Click > in front of the data series, and then configure the specified style of the series on the expanded panel.
Interaction
For details about whether the component supports the interaction function and how to use the interaction function, see Configuring Component Interaction.
Parent topic: Others
