Decoration
This section describes parameters of a decoration component.
Pattern
  • Size/Position
    • Size: width and height of the component. Unit: pixel.
    • Position: position where the component is located in the canvas. Unit: pixel.
    Figure 1 Decoration
  • Pattern
    • Display Mode: to set the display mode of the decoration component. The value can be Default, Proportion, Crop, or Stretch.
    • Pattern: pattern of the decoration component. DLV provides various preset border patterns for you to select.
Data
This component does not have data events.
Interaction
For details about whether the component supports the interaction function and how to use the interaction function, see Configuring Component Interaction.
