User Guide
- Preparatory Work
- Introducing the DLV Console
- How-Tos
- Managing Workspaces
- Creating Data Connections
- Creating Screens
- Developing Screens
- Managing Screens
- Managing Layers
Data Connection Management
- Data Connection Overview
- Using Static Data Sources
- Creating API Data Connections
- Creating CSV File Data Connections
- Creating Object Storage Service Data Connections
- Creating Data Warehouse Service Data Connections
- Creating Data Lake Insight Data Connections
- Creating MRS Hive Data Connections
- Creating MRS SparkSQL Data Connections
- Creating ClickHouse Data Connections
- Creating RDS for MySQL Data Connections
- Creating RDS for PostgreSQL Data Connections
- Creating RDS for SQL Server Data Connections
- Creating RDS for GaussDB Data Connections
- Creating GeminiDB Influx API Data Connections
- Creating Cloud Search Service Data Connections
- Creating DDM Data Connections
- Creating Oracle Data Connections
- Creating MySQL Data Connections
- Creating PostgreSQL Data Connections
- Creating SQL Server Data Connections
- Creating Elasticsearch Data Connections
- Editing Data Connections
- Searching for Data Connections
- Deleting Data Connections
- Managing Components
- Component Guide
- Screen Combination
- Integrating DLV into Third-Party Systems
- Change History
- Developer Guide
- API Reference
- What Is DLV Used For?
- Regions and AZs
- Can I Quickly Create a DLV Screen Using a Template?
- Can DLV Connect to Data Sources Through APIs?
- What Types of Data Connections Are Supported in DLV?
- How Do I Configure a CSV Data Source?
- How Do I Use the Interaction Function?
- What Can I Do If a Component Cannot Be Completely or Normally Displayed?
- How Do I Query Data Formats Supported by Different Components?
- What Can I Do When the WebGL Component Breaks Down?
More Documents
- Preparatory Work
- How-Tos
- Creating Screens
- Managing Screens
- Managing Layers
- Creating API Gateway Data Connections
- Creating a DAYU Data Connection
- Managing VPC Connections
- Component Guide
- What Is DLV?
- Regions and AZs
- How Many Screens Can I Create in DLV?
- API Reference (ME-Abu Dhabi Region)
- Developer Guide (ME-Abu Dhabi Region)
On this page
Show all
Help Center/
Data Lake Visualization/
User Guide (ME-Abu Dhabi Region)/
Component Guide/
Scatter Charts/
Bubble Chart
Bubble Chart
This section describes parameters of a bubble chart.
Figure 1 Bubble chart
Pattern
- Size/Position
- Size: width and height of the component. Unit: pixel.
- Position: position where the component is located in the canvas. Unit: pixel.
- Global Style
Font: text font.
- Margin
- Top: spacing between the top sides of the chart and the component layer. You can enter a value or click
to adjust the spacing.
- Bottom: spacing between the bottom sides of the chart and the component. You can enter a value or click
- Left: spacing between the left sides of the chart and the component. You can enter a value or click
- Right: spacing between the right sides of the chart and the component. You can enter a value or click
- X Axis
- X Axis: to show or hide the X axis by clicking
or
- Data Type: data type of the X axis. The options are Value, Category, Time, and Log.
- Scales: When Data Type is set to Value or Time, the number of displayed labels is automatically displayed based on the value of Scales. This parameter is invalid when Data Type is set to other values.
- Font Size: font size of the X axis text.
- Color: font color of the X axis text.
- Font Width: font width of the X axis text.
- Angle: angle of the X axis text.
- Axis Color: color of the X axis.
- Grid Color: grid line color of the X axis.
- Axis Unit: to set the unit, font size, and font color of the X axis.
Figure 2 X axis of a bubble chart - X Axis: to show or hide the X axis by clicking
- Y Axis
- Y Axis: to show or hide the Y axis by clicking
or
- Data Type: data type of the Y axis. The options are Value and Category.
- Scales: When Data Type is set to Value, the number of displayed labels is automatically displayed based on the value of Scales. This parameter is invalid when Data Type is set to Category.
- Font Size: font size of the Y axis text.
- Color: font color of the Y axis text.
- Font Width: font width of the Y axis text.
- Angle: angle of the Y axis text.
- Axis Label: to set the display format, maximum value, and minimum value of the Y axis.
- Axis Color: color of the Y axis.
- Grid Color: grid line color of the Y axis.
- Axis Unit: to set the unit and font color of the Y axis.
Figure 3 Y axis of a bubble chart - Y Axis: to show or hide the Y axis by clicking
- Legend
- Legend: to show or hide the legend by clicking
or
- Text: text style of the legend, including Font Size, Color, and Font Width.
- Layout: layout style of the legend, including Position, Left/Right Spacing, Top/Bottom Spacing, and Legend Spacing.
Figure 4 Legends of a bubble chart - Legend: to show or hide the legend by clicking
- Message
- Message: If you click
, a message will pop up when you hover over a previewed or published component.
- Triggering Mode: to set the triggering mode of messages. The options are Coordinate Axis and Data.
- Color: font color of the message.
- Font Size: font size of the message.
- Font Width: font width of the message.
Figure 5 Message of a bubble chart - Message: If you click
- Animation
- Click
or
next to Animation to hide or show animation, respectively.
- Duration: duration of the first rendering of the component, in ms.
- Animation Effect: The system provides multiple common animation slow-moving effects.
- Animate in Order: If this option is selected, the series are animated in sequence. If this option is deselected, all series are animated at the same time.
- Duration After Change: animation duration when the component data is updated, in ms.
- Start from Previous Position: If this option is selected, the animation is played from the position of the previous data when the component data is updated. If this option is deselected, the animation is played from the initial position when the component data is updated.
Figure 6 Animation (line chart) - Click
Data
For details about how to configure component data, see Configuring Component Data.
Interaction
For details about whether the component supports the interaction function and how to use the interaction function, see Configuring Component Interaction.
Parent topic: Scatter Charts
