Managing Layers
If multiple components are deployed or nested in the canvas, the layer function helps you quickly locate a component.
Modifying the Layer Position of a Component
Method 1: Select a component in the layer list and drag the component to a specific layer.
  Method 2: Right-click on a component in the canvas and choose Top, Bottom, Move Up, or Move Down.
  Deleting a Layer
In the layer area, select a component in the layer list or right-click a component in the canvas and click
 from the shortcut menu to delete the component.
