Copying Components
This section describes how to copy a component in the canvas. The copied component has the same pattern, data, and interaction configuration information as the original one.
- On the Screens page, locate the screen to be edited and click
 on the screen. The screen development page is displayed.
    Figure 1 Editing a screen
     - Right-click a component in the canvas and select Copy from the shortcut menu. Alternatively, right-click a component in the layer area and select Copy from the shortcut menu.
Alternatively, you can select a component, press Ctrl+C to copy the component, and then press Ctrl+V to paste the component.
Figure 2 Copying a component
