User Guide
- Preparatory Work
- Introducing the DLV Console
- How-Tos
- Managing Workspaces
- Creating Data Connections
- Creating Screens
- Developing Screens
- Managing Screens
- Managing Layers
Data Connection Management
- Data Connection Overview
- Using Static Data Sources
- Creating API Data Connections
- Creating CSV File Data Connections
- Creating Object Storage Service Data Connections
- Creating Data Warehouse Service Data Connections
- Creating Data Lake Insight Data Connections
- Creating MRS Hive Data Connections
- Creating MRS SparkSQL Data Connections
- Creating ClickHouse Data Connections
- Creating RDS for MySQL Data Connections
- Creating RDS for PostgreSQL Data Connections
- Creating RDS for SQL Server Data Connections
- Creating RDS for GaussDB Data Connections
- Creating GeminiDB Influx API Data Connections
- Creating Cloud Search Service Data Connections
- Creating DDM Data Connections
- Creating Oracle Data Connections
- Creating MySQL Data Connections
- Creating PostgreSQL Data Connections
- Creating SQL Server Data Connections
- Creating Elasticsearch Data Connections
- Editing Data Connections
- Searching for Data Connections
- Deleting Data Connections
- Managing Components
- Component Guide
- Screen Combination
- Integrating DLV into Third-Party Systems
- Change History
- Developer Guide
- API Reference
- What Is DLV Used For?
- Regions and AZs
- Can I Quickly Create a DLV Screen Using a Template?
- Can DLV Connect to Data Sources Through APIs?
- What Types of Data Connections Are Supported in DLV?
- How Do I Configure a CSV Data Source?
- How Do I Use the Interaction Function?
- What Can I Do If a Component Cannot Be Completely or Normally Displayed?
- How Do I Query Data Formats Supported by Different Components?
- What Can I Do When the WebGL Component Breaks Down?
More Documents
- Preparatory Work
- How-Tos
- Creating Screens
- Managing Screens
- Managing Layers
- Creating API Gateway Data Connections
- Creating a DAYU Data Connection
- Managing VPC Connections
- Component Guide
- What Is DLV?
- Regions and AZs
- How Many Screens Can I Create in DLV?
- API Reference (ME-Abu Dhabi Region)
- Developer Guide (ME-Abu Dhabi Region)
You can use a VPC connection to connect a cloud data source to DLV for data display on screens.
DLV supports the following data sources connected through VPC:
- DWS
- MapReduce Service ClickHouse
- RDS for MySQL
- RDS for GaussDB
- RDS for PostgreSQL
- GeminiDB for InfluxDB (RDS for GaussDB for Influx)
- RDS for SQL Server
- Cloud Search Service
- Custom data sources on ECSs
- Only users with the DLV FullAccess and VPCEndpoint Administrator permissions or users with the Tenant Administrator permission can create or delete VPC connections.
The Tenant Administrator permission has all cloud service administrator permissions except the IAM management permission. For security purposes, you are not advised to grant this permission to IAM users. Exercise caution when performing this operation.
- The data source instance to be connected has been created.
- The corresponding security group rules have been configured.
Create VPC Connections
- Log in to the DLV console.
- Choose Control Center > VPC Connection Management. Click Create VPC Connection.
Figure 1 Creating a VPC connection
- Configure the following parameters.
Table 1 Parameters for creating a VPC connection Parameter
Region
Select the region where the DLV screen is located.
Connection Name
Enter the name of the VPC connection.
Service Category
Select the type of the data source to be connected through the VPC. The following types of data sources are supported:
- DWS
- RDS for MySQL
- RDS for GaussDB
Instance
Instances of the data source you want to connect to. (This is required for all data sources except the custom data sources on ECSs.)
Private IP Addresses
Private IP addresses of ECSs. This parameter is mandatory only when custom data sources are configured on ECSs.
VPC ID
ID of the VPC used by ECSs. This parameter is mandatory only when custom data sources are configured on ECSs.
Network ID
IP address of the VPC subnet used by ECSs. This parameter is mandatory only when custom data sources are configured on ECSs.
Security Group ID
ID of the security group used by ECSs. This parameter is mandatory only when custom data sources are configured on ECSs. Use commas (,) to separate multiple IDs.
Figure 2 Connection parameters - Click OK.
After the VPC connection is added, you can choose Data > New Data Connection to create a data connection and use the VPC connection as the connection proxy.
Deleting VPC Connections
- Locate the row containing the VPC connection to be deleted, and click Delete in the Operation column.
