Updated on 2025-01-22 GMT+08:00
Use Process
Before developing a screen, understand the process of using DLV. Figure 1 illustrates the DLV use flowchart. You can perform all the operations in the flowchart on the DLV console.
- Creating data connections: Connect to data sources required for screen creation. If static data is used, skip this step.
- Creating screens: Use a template to create a screen.
- Editing screens: Configure the pattern, data, interaction of components and manage image layers.
- Previewing screens: Preview your created screens.
- Publishing screens: Publish your created screens.
Parent topic: How-Tos
