Help Center/
      Data Lake Visualization/
        User Guide (ME-Abu Dhabi Region)/
        Managing Screens/
      Importing and Exporting Screens
        Updated on 2025-01-22 GMT+08:00
DLV allows you to export a developed screen and import the exported screen to DLV.
Precautions for Importing Screens
- You can import screens that are exported from DLV in one region to DLV in another region.
 - You can import screens exported by one account or IAM user to DLV purchased by another user.
 - After the screen exported from an earlier edition of DLV is imported to a later edition of DLV, the screen configuration and components are still of the edition when the screen is exported. To use the latest edition of components, you need to add the components again on the screen.
 - After a screen is imported successfully, you need to reconfigure the data source of each component on the screen.
 - After a screen is imported successfully, the interaction needs to be recreated.
Exporting Screens
- Log in to the DLV console.
 - On the Screens page, locate the screen to be exported and click
 on the screen.
    Figure 1 Exporting a screen
Importing Screens
 - In the upper right corner of the Screens page, click Import Screen, select the exported screen, and click Open to import the screen.
If the import is successful, a message is displayed in the upper right corner of the console, indicating that the screen is imported successfully.
Figure 2 Importing a screen
   Parent topic: Managing Screens
