On this page
Show all
Task Center
Updated on 2022-12-08 GMT+08:00
You can view the progress and results of asynchronous tasks on the Task Center page.
The following tasks can be viewed:
  • Creating a DDM instance
  • Deleting a DDM instance
  • Changing class of a DDM instance
  • Scaling out a DDM instance
  • Scaling in a DDM instance
  • Restarting a DDM instance
  • Binding an EIP to a DDM instance
  • Unbinding an EIP from a DDM instance
  • Restoring data from current instance
  • Importing schema information
  • Scaling out a schema
  • Creating a consistent backup
  • Deleting a consistent backup
  • Restoring data using a consistent backup
  2. Click in the upper left corner and select a region and a project.
  3. Click in the upper left corner of the page and choose Database > Distributed Database Middleware.
  4. Choose Task Center in the left navigation pane, locate the required task, and view its details.
    • You can use the task name, order ID, or DB instance name/ID to locate the required task, or simply enter the target task name in the search box in the upper right corner.
    • You can click in the upper right corner to search for tasks executed within a specific period. The default time range is seven days.
      All tasks in the list can be retained up to one month.
    • You can view the tasks that are in the following statuses:
      • Running
      • Completed
      • Failed
    • You can view the task creation and completion time.
