Help Center/ Distributed Database Middleware/ User Guide (ME-Abu Dhabi Region)/ Backup Management/ Creating a Consistent Backup/ Creating a Backup
Creating a Backup
- You have logged in to the DDM console.
- The DDM instance that you want to back up is in the Running state.
- There are schemas available in the DDM instance.
- In the instance list, locate the DDM instance that you want to back up and click its name.
- In the navigation pane, choose Backups.
- On the displayed page, click Create Backup.
- In the displayed dialog box, enter a name for the backup and a brief description and click OK.
The time required depends on the amount of data to be backed up.
Parent topic: Creating a Consistent Backup
