Help Center/ Distributed Database Middleware/ User Guide (ME-Abu Dhabi Region)/ Schema Management/ Exporting Schema Information
Updated on 2022-12-08 GMT+08:00
Export schema information from the primary DDM instance for cross-region DR.
There are schemas available in the DDM instance that you want to export schema information from.
- Log in to the DDM console; in the instance list, locate the required DDM instance and click its name.
- On the displayed page, in the navigation pane, choose Schemas. Figure 1 Schema list
- On the displayed page, click Export Schema Information. All schema information of the current DDM instance is exported as a JSON file.
Parent topic: Schema Management
