Help Center/
Distributed Database Middleware/
User Guide (ME-Abu Dhabi Region)/
Parameter Template Management/
Modifying the Description of a Parameter Template
Updated on 2022-12-08 GMT+08:00
You can modify the description of a parameter template that you have created.
You cannot modify the description of any default parameter template.
- Click
in the upper left corner and select a region and a project.
- Click
in the upper left corner of the page and choose Database > Distributed Database Middleware.
- Choose Parameter Templates, click the Custom Templates tab, locate the parameter template whose description you want to modify, and click
in the Description column.
- Enter a new description. You can click
to submit or
to cancel the modification.
- The description contains up to 256 characters but cannot contain special characters >!<"&'=
- After the modification is successful, you can view the new description in the Description column.
Parent topic: Parameter Template Management
