Help Center/
      Distributed Database Middleware/
        User Guide (ME-Abu Dhabi Region)/
        FAQs/
        DDM Usage/
      Which Should I Delete First, Schema or Associated RDS DB Instances?
You should delete a schema first and then its associated RDS DB instances. If you delete the associated RDS DB instances before deleting the schema, the schema cannot be deleted. You need to delete it by deleting the associated DDM instance.
   Parent topic: DDM Usage
